  • DS18 GEN-X900.4 GEN-X 4-Channel Full-Range Class AB 900W Amplifier
CLEARANCE DS18 GEN-X900.4 GEN-X 4-Channel Full-Range Class AB 900W Amplifier
DS18
Part #294-8160
DS18
Part #294-8160
Model: GEN-X900.4
The DS18 GEN-X line of Cass DAB Amplifiers are durable and provide maximum wattage for your budget. These stylish amps will fit just about anywhere and supply all the power you need with great efficiency.
  • Full Range Class AB Amplifier
  • 4 channels at 900 watts (225 watts per channel)
  • Efficient power handling allows for easy installation of multiple amps
CLEARANCE $187.95
Order in the next 0 hr 28 min to ship today. Details
1In Stock
The DS18 GEN-X900.4 GEN-X 4-Channel Full-Range Class AB 900W Amplifier is a durable full-range amplifier for people who want an amplifier that will deliver plenty of power efficiently as possible. The included remote volume control knob allows for easy level adjustment when the amplifier can not easily be reached.
The GEN-X900.4 can be set up to power either full range speakers, subwoofers, or tweeters with it's built in crossovers and adjustable crossover points. Two independent crossovers allow for the ability to power different sets of speakers between the amplifier's four outputs.
With 90 watts RMS of power per channel at 2 ohms, 60 watts RMS of power per channel at 4 ohms, the GEN-X900.4 can also operate in a dual mono mode for a total output of 150 watts RMS per channel pair at 4 ohm bridged
Power output: 2 x 80W RMS (@ 4 ohms), 2 x 120W RMS(@ 2 ohms), 1 x 200W RMS (4 ohms bridged mono)
Frequency Response: 20 Hz - 20 kHz
Total harmonic distortion: 0.01%
Signal-to-noise ratio: 98 dB
Dimensions: 330 mm x 190 mm x 55 mm (13" x 7.4" x 2.16")
BrandDS18
ModelGEN-X900.4
Part Number294-8160
UPC663593065179
Weight7.3
Output Channels4
RMS Power Output (4 Ohms)80
