CLEARANCE Speaker Crossover 3-Way 8 Ohm 800/4,500 Hz 200W
Part #260-230
Part #260-230
This network is an excellent choice for high power 3-way systems. The woofer section rolls off 6 dB at 800 Hz while the tweeter section uses a 12 dB per octave roll off at 4,500 Hz. The midrange section uses a true band pass filter with a response of 750-5,000 Hz. 12 dB per octave roll off.
- Crossover network is an excellent choice for higher power 3-way systems
- The midrange section uses a true band pass filter with a response of 750-5,000 Hz
- All crossover frequencies are rated into a 8 ohm load
We'll send you an email when Speaker Crossover 3-Way 8 Ohm 800/4,500 Hz 200W is back in stock or available for preorder.
