  • Chauvet DJ COLORstrip DMX RGB LED Linear Wash Light
CLEARANCE Chauvet DJ COLORstrip DMX RGB LED Linear Wash Light
Chauvet DJ
Part #243-7106
Chauvet DJ
Part #243-7106
Model: COLORstrip
CHAUVET's COLORstrip™ is an LED-fitted strip fixture. The unit can be controlled via four DMX channels, multiple modes accessible via the control panel–pre-programmed flash, color chase, sequential color chase, color mixing and color fade patterns–or an optional LED-FS1 controller.
  • 4-channel DMX-512 LED linear wash light
  • Blackout/static/dimmer/strobe
  • Static colors and RGB color mixing with or without DMX controller
  • Built-in automated programs via master/slave or DMX
  • Built-in sound activated programs via master/slave or DMX
  • Compatible with CHAUVET® Satellite™ system
  • Additional power output: max 15 units @ 120V (see manual for details)
CHAUVET's COLORstrip™ is an LED-fitted strip fixture. The unit can be controlled via four DMX channels, multiple modes accessible via the control panel, or an optional LED-FS1 controller. The COLORstrip™ features built-in programs with automatic and sound-active triggers, and allows access to popular preset RGB mixed colors: yellow, purple, cyan and white. The fixture is equipped with pre-programmed flash, color chase, sequential color chase, color mixing and color fade patterns. Jacking the COLORstrip™ into a DMX controller gives the programmer access to all pre-programmed features as well as to speed adjustments for fade and flash. At 38" long, 2.5" wide, and weighing less than 5 lbs., it is ideal for creating "runway" effects without cluttering up the catwalk.
Specifications: • Beam angle: 53° x 27° • Field angle: 68° x 46° • Lux: 1,127 @ 1m • Light source: 384 (128 red, 128 green, 128 blue) LEDs • Power and current: 120V, 60 Hz: 28W, 0.4A operating, 0.4A inrush • AC power: auto-switching 100~240 VAC, 50/60 Hz • Weight: 4.5 lbs.  (2 kg) • Size: 38" x 2.5" x 6" (965 x 64 x 152 mm).
BrandChauvet DJ
ModelCOLORstrip
Part Number243-7106
UPC781462214111
Weight7.05
DMX-ControllableYes
Light TypeLinear Strip
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
