  • Celestion TF0818MR 8" Professional Speaker 100W
Celestion
Part #294-2056
Celestion
Part #294-2056
Model: TF0818MR
Easy to install in an enclosure, the sealed-back Celestion TF0818MR 8" pro mid driver is characterized by high efficiency and smooth, accurate response.
  • 99 dB sensitivity and 100 watts RMS power handling
  • 1.75" high temperature copper voice coil wound on polyimide former for increased reliability
  • Designed for use in large 3-way systems
  • Closed back chassis simplifies cabinet manufacture, eliminating need for separate mid-range enclosure
Your Price: $69.50
MSRP: $104.25
Save $34.75 (33%)
Out of Stock
Celestion's TF0818MR 8" professional midrange speaker features and integrated sealed chassis that isolates the driver's diaphragm a companion woofer's "back pressure", which eliminates the need to construct a separate sub-enclosure. The TF0818MR produces high-SPL, low distortion reproduction of the all-important frequency range. It features a 1.75" high-temp voice coil and a 31 oz. ceramic ferrite magnet, which contribute to the driver's very high output and low distortion.
BrandCelestion
ModelTF0818MR
Part Number294-2056
UPC739894527842
Weight4.5
Nominal Diameter8"
Power Handling (RMS)100 Watts
Power Handling (MAX)200 Watts
Frequency Response800 to 5,000Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter1.75"
Resonant Frequency (Fs)453Hz
DC Resistance (Re)6.63Ω
Voice Coil Inductance (Le)0.31mH
Cone MaterialPaper / Kevlar
Surround MaterialTreated Paper
Overall Outside Diameter8.19"
Baffle Cutout Diameter7.2"
Depth3.35"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
