  • Celestion Pulse10 10" 200W Bass Guitar Speaker 8 Ohm
Celestion
Part #294-2462
Celestion
Part #294-2462
Model: Pulse10
Celestion designed the Pulse bass guitar speakers in response to the specific needs of today's bass players. Delivering incredible detail and definition, warm midrange response, and powerful low end. The Pulse 10 will provide reliable amplification in any situation.
  • Long throw design with 4 mm Xmax for powerful bass you can feel
  • 8 Ohm impedance provides an easy load to most amps, also ideal when using multiples
  • Reinforced steel frame keeps cost down without sacrificing reliability
  • 2" voice coil on a Polyimide former with adequate venting handles 200 watts
Your Price: $99.00
MSRP: $148.50
Save $49.50 (33%)
Order in the next 3 hr 1 min to ship today. Details
With its robust steel-chassis, Celestion's PULSE 10 provides rock-solid bass performance whether alone in a single speaker amp, or in a 4x10 or even an 8x10 cab. Expect a tight, punchy low end with a warm mid-range that is full of presence, bringing focus and articulation to your playing. This heavy-duty driver truly delivers bass you can feel as well as hear.
Overall Specifications : • Nominal diameter: 10" • Power rating: 200 watts • Nominal impedance: 8 ohms • Sensitivity: 94 dB • Chassis type: Pressed steel • VCdia: 2" • Voice coil material: Copper • Magnet type: ferrite • Frequency range: 45-3,500 Hz • Fs: 68 Hz • DC resistance, Re: 6.03 ohms.
Mounting Information : • Diameter: 10.1" • Overall depth: 4.3" • Cut-out diameter: 9" • Number of mounting holes: 8 • Weight: 6.6 lbs.
BrandCelestion
ModelPulse10
Part Number294-2462
UPC739894596855
Weight7.75
Nominal Diameter10"
Power Handling (RMS)200 Watts
