  • Celestion Heritage G12-65 12" 8 Ohm Guitar Speaker 65W
Celestion
Part #294-2232
Celestion
Part #294-2232
Model: Heritage G12-65
The Heritage G12-63 8 ohm speaker was originally created as a higher-power handling variant of the G12M Greenback, and is now widely regarded as one of the best speakers ever produced for use in a 4x12 cabinet.
Your Price: $169.00
MSRP: $253.50
Save $84.50 (33%)
Only 1 In Stock
With its fast attack and tightly controlled low-end, the G12-65 became a firm favorite in the '80s with hard rock players. The precisely tuned midrange and crisp defined top-end contribute to an aggressive crunch sound that punches through the mix while the mid-range warmth and detail give weight and depth to single notes.
Like the original G12-65, the Heritage Series re-creation of this legendary Celestion guitar loudspeaker has a tone that's best described as sitting somewhere between the G12M and the Classic Lead 80, with plenty of definition for high-gain playing styles without being too bright or aggressive. By adhering precisely to the initial design notes, specifications, materials and construction techniques, the Heritage Series G12-65 dishes up the cherished guitar tones of the '80s with almost unnerving accuracy.
Overall Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 65 watts • Nominal impedance: 8 ohm • Sensitivity: 97 dB • Chassis type: Pressed steel • VCdia: 1.75" (44.5 mm) • Voice coil material: Round copper • Magnet type: Ceramic • Frequency range: 80-5,000 Hz • Fs: 85 Hz • DC resistance, Re: 6.9 ohm.
Mounting Information: • Diameter: 12.2" (309 mm) • Overall depth: 5" (128 mm) • Magnet structure diameter: 5.7" (145 mm) • Cut-out diameter: 11.1" (283 mm) • Mounting slot dimensions: 0.31", (7.9 mm Ø) • Number of mounting slots: 4 • Mounting slot PCD: 11.7" (297 mm) • Weight: 12.1 lbs. (5.5 kg).
BrandCelestion
ModelHeritage G12-65
Part Number294-2232
UPC739894305303
Weight9.1
Nominal Diameter12"
Power Handling (RMS)65 Watts
