  • Celestion H1-7050 1" Exponential Horn 70 x 50 2-Bolt
CLEARANCE Celestion H1-7050 1" Exponential Horn 70 x 50 2-Bolt
1 Question, 1 Answer or
Celestion
Part #294-2942
Celestion
Part #294-2942
Celestion's unique H1-7050 "No Bell" cast aluminum horn features imbedded elastomer panels to damp the bell-like resonances that are common with most aluminum horns. The controlled 70° H x 50° V dispersion pattern directs the output right where you want and keeps unwanted reflections to a minimum.
  • Embedded elastomer side panels damp resonances for smoother response
  • Standard 2-bolt mount is compatible with many popular drivers
  • Thick cast aluminum construction can support the weight of most compression drivers
  • 70° H x 50° V dispersion delivers room filling sound with minimal unwanted reflections
  • Exponential horn flare for smooth response throughout the useable bandwidth
The heavy cast aluminum H1-7050 "No Bell" exponential horn from Celestion is a unique horn that includes integrated elastomer side panels to damp unwanted resonances resulting in smooth response with virtually no audible ringing. With a 70° H x 50° V radiation pattern, this horn will produce room filling output while minimizing unwanted reflection. With a standard 2-bolt mount and loading down to 1,500 Hz, the H1-7050 is compatible with many of the most popular compression drivers available. Finally, the powder coated cast aluminum construction ensures that this horn will stand up to the years of use and abuse that professional speakers can be exposed to.
Specifications: • Throat diameter: 1" • Driver mounting: standard 2-bolt • Nominal coverage: 70°H x 50° V • Cutoff frequency: 1,500 Hz • Dimensions: 7" H x 7" W x 3-1/2" D • Cutout dimensions: 4" H x 5-1/2" W.
BrandCelestion
ModelH1-7050
Part Number294-2942
UPC848864058122
Weight1.4
ConstructionAluminum
Entry / Throat Diameter1"
Mounting Type2-Bolt
