  • Celestion FTX1225 12" Coaxial Full-Range Professional Driver
Celestion
Part #294-2098
Celestion
Part #294-2098
Model: FTX1225
Celestion's unique FTX1225 coaxial full-range driver uses a single FEA optimized magnet as the common motor for both the 12" low frequency and 1.75" compression driver resulting in enhanced coherence and minimal distortion.
  • Capable of true full range frequency response from 50 to 20,000 Hz
  • Coaxially mounted 1.75" Polyimide compression driver delivers predictable off axis response
  • Demodulation ring lowers inductance and improves damping for lower distortion
  • Rugged cast aluminum frame is designed to minimize unwanted reflections
  • Can be used with both passive and active crossovers (not included)
Your Price: $299.00
MSRP: $448.50
Save $149.50 (33%)
Only 3 In Stock
Perfect for ultra-compact high output speakers systems, Celestion's FTX1225 12" coaxial full-range features fully integrated low and high frequency drivers which are powered by a common motor assembly. Bringing the acoustic centers of the two drivers closer together improves both time alignment and signal coherence for more natural and predictable response. Other features include an aluminum demodulation ring, edgewound voice coils (woofer and compression driver), and a cast aluminum frame with integrated voice coil vents.
By concentrically aligning low and high frequency drivers, coaxial loudspeakers act as a single source, often providing improvements in signal alignment when compared to a traditional two-way system. Powered by a common magnet motor assembly (same magnet for both elements) Celestion's FTX coaxial range features fully combined LF and HF components in a single chassis. This brings the voice coils and hence the acoustic centers of the two drivers closer together, delivering further improvements in signal coherence for a more natural sounding audio reproduction.
Specifications (Woofer): • Power Handling: 300 watts RMS/ 600 watts continuous program • VC dia: 2.5" • Le: 3.36 mH • Impedance: 8 ohms • Re: 5.39 ohms • Frequency response: 50 – 4,000 Hz • Fs: 47.3 Hz • SPL: 97 dB 1W/1m • Vas: 2.99 cu. ft. • Qms: 5.39 • Qes: 0.43 • Qts: 0.39 • Xmax: 4 mm
Specifications (Compression driver): • Power handling: 60 watts RMS/120 watts continuous program (with recommended crossover of 2,000 Hz/12 dB slope) • VCdia: 1.75" • Impedance: 8 ohms • Frequency response: 1,000 – 20,000 Hz • SPL: 104 dB 1W/1m
Dimensions: • Outside diameter: 12.5" • Cutout diameter: 11.25" • Depth: 6.6"
BrandCelestion
ModelFTX1225
Part Number294-2098
UPC739894591157
Weight15.5
Nominal Diameter12"
Bolt Circle Diameter11.75
Power Handling (RMS)300 Watts
Power Handling (MAX)600 Watts
Frequency Response50 to 4,000Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)42.1Hz
DC Resistance (Re)5.74Ω
Voice Coil Inductance (Le)0.5mH
Mechanical Q (Qms)3.35
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.4
Compliance Equivalent Volume (Vas)0.43ft³
Mechanical Compliance of Suspension (Cms)0.3mm/N
BL Product (BL)12.54T·m
Diaphragm Mass Inc. Airload (Mms)47.53g
Surface Area of Cone (Sd)169.1cm²
Cone MaterialPaper / Kevlar
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Overall Outside Diameter12.5"
Baffle Cutout Diameter11.25"
Depth6.61"
Sealed Volume0.85ft³
Sealed F391.4Hz
Vented Volume1.13ft³
Vented F336.1Hz
