  • Celestion FTX0820 8" Coaxial Full-Range Professional Driver
Celestion
Part #294-2096
Celestion
Part #294-2096
Model: FTX0820
Celestion's unique FTX0820 coaxial full-range driver uses a single FEA optimized magnet as the common motor for both the 8" low frequency and 1.4" compression driver resulting in enhanced coherence and minimal distortion.
  • Capable of true full range frequency response from 70 to 20,000 Hz
  • Coaxially mounted 1.4" Polyimide compression driver delivers predictable off axis response
  • Demodulation ring lowers inductance and improves damping for lower distortion
  • Rugged cast aluminum frame is designed to minimize unwanted reflections
  • Can be used with both passive and active crossovers (not included)
Your Price: $192.50
MSRP: $288.75
Save $96.25 (33%)
Only 3 In Stock
Perfect for ultra-compact high output speakers systems, Celestion's FTX0820 8" coaxial full-range features fully integrated low and high frequency drivers which are powered by a common motor assembly. Bringing the acoustic centers of the two drivers closer together improves both time alignment and signal coherence for more natural and predictable response. Other features include an aluminum demodulation ring, edgewound voice coils (woofer and compression driver), and a cast aluminum frame with integrated voice coil vents.
By concentrically aligning low and high frequency drivers, coaxial loudspeakers act as a single source, often providing improvements in signal alignment when compared to a traditional two-way system. Powered by a common magnet motor assembly (same magnet for both elements) Celestion's FTX coaxial range features fully combined LF and HF components in a single chassis. This brings the voice coils and hence the acoustic centers of the two drivers closer together, delivering further improvements in signal coherence for a more natural sounding audio reproduction.
Specifications (Woofer): • Power Handling: 200 watts RMS/ 400 watts continuous program • VC dia: 2" • Le: 0.84 mH • Impedance: 8 ohms • Re: 5.9 ohms • Frequency response: 70 – 4,000 Hz • Fs: 63.9 Hz • SPL: 94 dB 1W/1m • Vas: 0.75 cu. ft. • Qms: 4.7 • Qes: 0.24 • Qts: 0.23 • Xmax: 2 mm
Specifications (Compression driver): • Power handling: 40 watts RMS/ 60 watts continuous program (with recommended crossover of 2,200 Hz/12 dB slope) • VCdia: 1.4" • Impedance: 8 ohms • Frequency response: 1,500 – 20,000 Hz • SPL: 103 dB 1W/1m
Dimensions: • Outside diameter: 8.5" • Cutout diameter: 7.36" • Depth: 4.49"
BrandCelestion
ModelFTX0820
Part Number294-2096
UPC739894591058
Weight10.05
Nominal Diameter8"
Bolt Circle Diameter8.27
Power Handling (RMS)200 Watts
Power Handling (MAX)400 Watts
Frequency Response70 to 20,000Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)78.8Hz
DC Resistance (Re)5.9Ω
Voice Coil Inductance (Le)0.84mH
Mechanical Q (Qms)4.7
Electromagnetic Q (Qes)0.242
Total Q (Qts)0.231
Compliance Equivalent Volume (Vas)0.75ft³
Mechanical Compliance of Suspension (Cms)0.238mm/N
BL Product (BL)14.4T·m
Diaphragm Mass Inc. Airload (Mms)21.12g
Surface Area of Cone (Sd)227.1cm²
Cone MaterialPaper / Kevlar
Surround MaterialCloth
Overall Outside Diameter8.5"
Baffle Cutout Diameter7.36"
Depth4.49"
Sealed Volume0.3ft³
Sealed F3307Hz
Vented Volume0.75ft³
Vented F378.2Hz
