  • Cable Wire Tie Adhesive Mount 30 lb Tensile 10 Pcs.
Part #080-515
Part #080-515
Don't leave your wires dangling from the ceiling or scattered on the floor, use nylon self-adhesive mounting pads in conjunction with cable ties for a neat and organized finish.
  • UL approved nylon 6/6 94V-2
  • High strength synthetic polymer adhesive
  • Sold in convenient 10 packs
  • Mounting holes for heavy cable ties rated up to 30 lbs.
Your Price: $2.99
Quantity:Qty: 1-9 $2.99/ea
Quantity:Qty: 10+$2.69/ea
Order in the next 3 hr 16 min to ship today. Details
Make sure you have a package of nylon self-adhesive tie mounts in your tool belt when you're working with cable ties. After you neatly tie up wires, you don't want them to sag or lay on the floor. Instead, stick or screw the mounting pads on the wall or ceiling along the path of the wires. Then slide the cable tie through the pad and around your wires for a professional finish. The heavy duty nylon pads work with cable ties up to .17" wide and 30 lbs. tensile strength. UL's flammability rating for the nylon pad is 94 V-2.
Specifications: • Nylon dimensions: .75" L x .75" W x .153" H • Mounting holes: .126" D • Cable tie slot: .17" W.
Part Number080-515
UPC844632038013
Unit of MeasurePackages
Weight0.0264
ColorNatural
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
