  • CAIG DeoxIT D5S-6 Spray 5 oz. with Perfect Straw
CLEARANCE CAIG DeoxIT D5S-6 Spray 5 oz. with Perfect Straw
CAIG Laboratories
Part #341-200
CAIG Laboratories
Part #341-200
Model: D5S-6P
CAIG DeoxIT D5S-6 fast-acting deoxidizing solution cleans, preserves, lubricates, and improves conductivity on all metal connectors and contacts. Use as a general treatment for all conductive metal surfaces, and on non-critical metal surfaces with severe oxidation and corrosion. New 60th anniversary can includes Perfect-Straw applicator attached permanently to the spray nozzle to prevent loss.
  • Cleans, lubricates, and protects connectors and contacts
  • Helps restore conductivity to your connections
  • Environmentally safe, non-ozone depleting
  • Ensures the maximum performance of electronic audio and video equipment
  • Also works great on automotive electrical systems
  • Straw permanently installed to nozzle to prevent loss
DeoxIT® D-Series – Contact Cleaner & Rejuvenator
CAIG DeoxIT is a must have for preserving and lubricating connectors, but also improves conductivity of contacts. If the metal surface is discolored and the corrosion is severe, DeoxIT dissolves the contamination and protects the surface. Not only does DeoxIT remove corrosion, it also seals and protects all electrical connections, and reduces intermittent failures, arcing, wear, and abrasion. Temperature range: -34°C to 200°C. Provides light 5% coating. Flammable (until solvent evaporates). Contains no ozone-depleting CFCs. 5 oz can.
Dual spray nozzle can deliver a wide spray or a straight to the spot application with the attached straw. Perfect-Straw™ cannot be lost, because it is permanently attached to the spray nozzle.
More than a Contact Cleaner . . . Improves & Protects Connections!
DeoxIT® D-Series contact cleaner is a fast-acting deoxidizing solution that cleans, protects, lubricates and improves conductivity on all metal connectors and contacts.
Use as a general treatment for connectors, contacts and other metal surfaces, and on non-critical metal surfaces with severe oxidation and corrosion. If the metal surface is discolored, it is severe. DeoxIT® dissolves the contamination and protects the surface.
For reference, DeoxIT® has approximately 20% cleaning action.
KEY FEATURES:
  • Improves Conductivity
  • Deoxidizes, Cleans and Preserves
  • Reduces Intermittent Connections
  • Reduces Arcing & RFI
  • Reduces Wear & Abrasion
  • Temperature Range, -34 C (-29 F) to +200 C (400 F)
Formulation:
5% DeoxIT® D100L
75% Odorless mineral spirits (CAS 64742-88-7)
20% DIFLUOROETHANE (CAS 75-37-6)
BrandCAIG Laboratories
ModelD5S-6P
Part Number341-200
UPC697429002007
Weight0.75
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
