  • ButtKicker BK-mini-LFE Mini Low Frequency Effect Transducer Bass Shaker
ButtKicker
Part #300-9406
ButtKicker
Part #300-9406
Model: BK-mini-LFE
The BK-mini-LFE mini LFE from ButtKicker is designed for use on a single seat or video game chair, and adds the 4th dimension of sound to your video games and music without disturbing others.
  • Single-serving buttkicking
  • Smallest ButtKicker mounts directly to seats
  • Patented magnetically suspended piston design
  • Lower frequency response than nearly any other tactile transducer
  • Nearly indestructible design, with thermal cutoff switch
Your Price: $109.99
MSRP: $129.95
Save $19.96 (15%)
ButtKicker® brand BK-mini-LFE mini LFE low frequency effect audio transducers are based on the larger BK-LFE tactile transducers that have received with rave reviews around the world since they were introduced in late 1999. Where the large BK-LFE tactile transducer is meant for adding the 4th dimension of sound to a group of chairs, the BK-mini-LFE is designed as a single seat transducer that requires minimal power.
ButtKicker Bass Shakers are built using a revolutionary, patented magnetically suspended piston design. Not only does this design create more accurate low frequency effects (drummers swear by them for monitoring), it also lasts longer! The magnetically suspended piston design pushes the resonant frequency of each ButtKicker transducer down to an ultra-low 9 Hz, allowing for a truly infrasonic, and usable, frequency range of 10 to 350 Hz! While other transducers produce their peak output at 60 to 80 Hz, ButtKickers are still going strong up to three octaves lower.
Experience the 4th dimension of sound with realistic tactile and sound effects such as earthquakes, thunderstorms, rocket launches, tidal waves, explosions, tornadoes, volcanoes, dinosaurs,  and high quality musical bass playback that you never knew existed on your music, movies, and video games--all without disturbing others in the same room!
Each ButtKicker transducer piston is built using large gauge coil wire, and is surrounded by a large metal housing that acts as a heatsink. Should the coil wire exceed 150°F (75°C), an internal thermal switch disconnects the ButtKicker from the amplifier for cooling. This allows for years of maintenance-free use! Five-way binding posts offer nearly endless amplifier connection options, and all ButtKicker transducers are proudly made in the U.S.A.
Note: ButtKicker transducers are able to operate at any angle. For the best possible output, with the lowest possible distortion, it is recommended that ButtKicker Bass Shaker transducers be mounted in their vertical, upright position.
Specifications: • Power handling: 50 watts minimum, 250 watts max • Impedance: 4 ohms • Frequency response: 10-350 Hz • Fs: 9 Hz • Overall dimensions (H x W x D): 3" x 4.815" x 4.34" • 12.8" long speaker wire lead • Weight: 2 lbs.
BrandButtKicker
ModelBK-mini-LFE
Part Number300-9406
UPC898114000180
Weight2.3
ApplicationLow Frequency Bass Shaker
Power Handling (RMS)50 Watts
