  • Belden 1189A RG-6/U Quad Shield Coaxial Cable 18 AWG Copper-Clad Conductor 75 Ohm 250 ft. USA
Belden
Part #102-1404
Belden
Part #102-1404
Model: 1189A 010250
For the least possible interference and crosstalk, use Belden 1189A RG-6/U Quad Shield coaxial cable.
  • High-performance coaxial wire for audio/video installations
  • 18 AWG solid 0.040" bare copper-covered steel conductor
  • Electrically superior gas-injected foam polyethylene insulation
  • Duobond® IV quad shield provides 100% coverage
  • Tough, long-lasting PVC outer jacket
Your Price: $77.98
MSRP: $110.99
Save $33.01 (30%)
Order in the next 2 hr 25 min to ship today. Details
2In Stock
Belden's 1189A Quad Shield coaxial cable features four alternating layers of poly-foil shielding and aluminum braid, the combination of which provides 100% coverage. 1189A is recommended for all CATV/CCTV applications that require an RG-6/U specification cable with a 75 ohm rated impedance. FPE insulation and black PVC jacket.
Specifications: • Center conductor: 0.040" dia. bare copper covered steel • Insulation: 0.180" dia. gas-injected FPE • Shield: Duofoil® tape bonded foil/tape/foil combined with braided aluminum, a second layer of Duofoil®, and a second aluminum braid • Outer jacket: PVC • Nominal impedance: 75 ohms • Velocity of propagation: 83% • Capacitance: 16.2 pF/ft. • Nominal attenuation: 0.67 dB/100 ft. @ 1 MHz • Overall diameter: 0.294".
BrandBelden
Model1189A 010250
Part Number102-1404
UPC848864005904
Weight8.95
Cable RatingUL Approved|CM Rated
Coaxial Cable TypeRG-6/U Quad Shield
Jacket ColorBlack
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
