  • Bash 500S Digital Subwoofer Plate Amplifier 500W RMS
CLEARANCE Bash 500S Digital Subwoofer Plate Amplifier 500W RMS
Bash
Part #300-752
Bash
Part #300-752
Model: 500S
The Bash 500 watt Subwoofer Amplifier offers the combination of clean output and high power which makes the BASH amplifiers some of the best sounding subwoofer amplifiers on the market.
  • High power output in a compact, lightweight design
  • Speaker and line level inputs for connection to any stereo
  • Limiting circuit prevents audible clipping and protects woofers
  • Auto On/Off detects an input signal eliminating the need to power the amp on
  • Phase reversal switch allows for optimal room placement
BASH patented subwoofer amplifier technology was developed to offer extreme amounts of power without the wasted heat and energy of traditional amplifier designs. Add to this an intelligent circuit design, and you get benefits such as extremely low distortion and high signal to noise ratios. The combination of clean output and high power makes the BASH amplifiers some of the best sounding subwoofer amplifiers on the market. Features: 50 to 150 Hz low-pass crossover, 0° or 180° phase, line level inputs, speaker level inputs, line outputs, master on/off switch, auto on.
• 500 watts RMS @ 0.5% THD into 4 ohm load
• Signal to noise ratio: 105 dB (A-weighted)
• Line-in and high-level in crossovers: Adjustable 50 to 150 Hz, 12 dB/octave low-pass crossover
• LFE-in crossovers:  Fixed 330 Hz, 12 dB/octave low-pass crossover
• Power requirements: 120 VAC, 60 Hz
• Dimensions: 12" W x 8" H x 3-1/2" D
• Cabinet cutout: 11" x 7"
BrandBash
Model500S
Part Number300-752
UPC844632001390
Weight6
