  • BOSS R2504 RIOT 1000 Watt 4 Channel MOSFET Car Audio Amplifier
Boss Audio Systems
Part #265-3988
Boss Audio Systems
Part #265-3988
Model: R2504
The 1,000 watt max, four channel RIOT R2504 Class AB amplifier from BOSS is an unbelievable value. Choose the R2504 when moving door and dash speaker amplification from the head unit to a dedicated amplifier. 2-ohm stability for powering a pair of speakers per channel.
  • Class AB topology, MOSFET power supply, 2-ohm stable, and fully protected
  • 4 x 90W RMS @ 4 Ohms power output
  • Remote subwoofer level control for driver's seat adjustments
  • Much more dynamic, clear, and powerful than head unit amplification
  • Stealth black anodized aluminum chassis
  • BOSS RIOT Series amplifiers are some of the best values in car audio amplification
Your Price: $118.98
MSRP: $169.99
Save $51.01 (30%)
If you're still using your head unit for amplification, you have no idea what you're missing! Head units are often unable to provide the loud, dynamic sound you want, and can distort (or even damage) your speakers at even medium volume levels.
That's where the BOSS RIOT Series of amplifiers comes in. Tried-and-true Class AB amplifier topology, 2-ohm stable (for powering a pair of 4-ohm speakers off a single channel), and way more than enough power for even the hungriest door, dash, or deck speaker. The R2504 can also be set up for dual 2.1 (dual tri-mode) use to power two pairs of stereo speakers and two mono subwoofers (passive crossover values are listed in the manual).
BOSS built the RIOT Series amplifiers with advanced features that are usually associated with amplifiers at more than twice the price: thermal and short circuit protection, soft turn-on circuit, remote turn-on/off, nickel-plated low-level and high-level inputs, LED power and protection indicators, all housed in a stealth black anodized aluminum chassis.
The R2504 also includes a MOSFET PWM power supply (for 4-ohm bridged-mono operation), dual variable 35 to 160 Hz low-pass crossovers, dual selectable fixed 80 Hz high-pass crossovers, a variable 0 to 18 dB bass boost, and a remote subwoofer level control for dialing in the perfect amount of bass from the driver's seat. Mounting hardware included.
Specifications: • Power output: 4 x 90W RMS (@ 4 ohms), 4 x 250W max (@ 2 ohms), 2 x 500W max (4 ohms bridged-mono) • Frequency response: 9 to 50,000 Hz • Signal-to-ratio: >102 dB • Total harmonic distortion: 0.01% @ RMS power output • Damping factor: >125 • Dimensions (L x H x W): 10.44" x 2.25" x 11.57".
BrandBoss Audio Systems
ModelR2504
Part Number265-3988
UPC791489115247
Weight7
Input TypeRCA Line Level-Speaker Level
Output Channels4
RMS Power Output (4 Ohms)90
Special Features2 ohm Stable-Bridgeable
