  • B652 5.1 Home Theater Surround Sound Speaker System with 10" Subwoofer
CLEARANCE B652 5.1 Home Theater Surround Sound Speaker System with 10" Subwoofer
Part #300-689
Part #300-689
Enjoy true 5.1 channel surround sound with this timber-matched speaker system, all you need is a home theater receiver. Every speaker in this system is designed in conjunction with one another to match both aesthetically and sonically. Featured in this package are the Dayton Audio B652 bookshelf speakers as the front channels. Rounding out the bottom end is a 10" powered subwoofer that works perfectly in small to medium sized rooms. Learn more about each speaker included in this package below.
  • B652 6-1/2" woofer provides surprisingly full, punchy bass output
  • The compact B452 has a wall-mountable enclosure perfect for use as rear channels
  • C452 adds clarity and detail to dialogue for TV and movies
  • Subwoofer has a downward-firing flared port design for clean, powerful bass
  • Speaker wire included for installing speakers
  • LFE cable or additional speaker wire for subwoofer installation sold separately
Dayton Audio B652 6-1/2" 2-Way Bookshelf Speaker Pair
Measuring under 12" tall, these small but mighty speakers will never overwhelm the decor in any room. The B652's 2-way design features a 6-1/2" polypropylene cone woofer and a 5/8" polycarbonate ferrofluid-cooled dome tweeter to reproduce audio accurately from 70 to 20,000 Hz. Installation features include quick-connect speaker terminals and keyhole hanger.
Specifications: • Woofer: 6-1/2" polypropylene • Tweeter: 5/8" polycarbonate ferrofluid cooled • Power handling: 40 watts RMS/75 watts max • Impedance: 6 ohms • Frequency response: 70-20,000 Hz • Sensitivity: 87 dB 1W/1m • Dimensions: 11-13/16" H x 7-1/16" W x 6-7/16" D.
Dayton Audio B452 4-1/2" 2-Way Bookshelf Speaker Pair
Don't judge a speaker by its size! The Dayton Audio B452 4-1/2" bookshelf speaker is the smallest in the Dayton Audio family, but the sound is big. A newly-designed 4-1/2" polypropylene cone woofer with 4-layer voice coil achieves excellent balance and listenability when combined with the 5/8" ferrofluid-cooled polycarbonate tweeter, for surprisingly rich, detailed sound from a small, affordable speaker. While cheap speakers use plastic enclosure parts to cut costs, the inexpensive B452 uses a sturdy wood-composite cabinet that minimizes resonance and enhances warmth without sacrificing clarity.
Specifications: • Woofer: 4-1/2" polypropylene cone with 4-layer voice coil • Tweeter: 5/8" polycarbonate dome with ferrofluid cooling • Power handling: 30 watts RMS/60 watts max • Impedance: 8 ohms • Frequency response: 85-20,000 Hz • Sensitivity: 84 dB 1W/1m • Dimensions: 9.5" H x 5.5" W x 5.7" D.
Dayton Audio C452 Dual 4-1/2" 2-Way Center Channel Speaker
The 2-Way design of the C452 employs dual 4-1/2" polypropylene woofers to produce the lows and mids while the 5/8" polycarbonate tweeter delivers accurate transparency to the dialogue of your favorite TV programs and movies. The sleek appearance of this speaker will blend into your home furnishings with its black vinyl finish. Rubber feet and keyhole brackets are included so you can mount this center channel to you wall above or below your TV, or place it directly on a shelf.
Specifications: • Power handling: 60 watts RMS, 120 watts max • Impedance: 6 ohms • Woofer: Dual 4-1/2" polypropylene cone with 4-layer voice coil • Tweeter: 5/8" polycarbonate with ferrofluid cooling • Frequency response: 85-20,000 Hz • Sensitivity: 86 dB 1W/1m • Crossover: First order high pass • Dimensions: 5.5" H x 15.75" W x 5.7" D.
Dayton Audio SUB-1000 10" 100 Watt Powered Subwoofer
The Dayton Audio SUB-1000 10" powered subwoofer system is the perfect addition to any home theater system. This powered sub features a bottom-firing, flared port, bass reflex design for reduced port noise and increased bass response. It also utilizes a long-throw 10" woofer and up to 100 watts of house-shaking power.
Specifications: • Power output: 100 watts RMS • Frequency response: 30-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch • Auto on/off • Power requirements: 120 VAC, 60 Hz • Dimensions (rubber feet included): 14-3/4" H x 14-3/16" W x 15-3/4" D.
Note: To learn more about each speaker included in this home theater speaker system, please click the item number in the table below.
Part Number300-689
UPC848864060897
Weight60.15
