  • B&C DE985TN-8 2" Titanium Compression Driver 8 Ohm 4-Bolt
CLEARANCE B&C DE985TN-8 2" Titanium Compression Driver 8 Ohm 4-Bolt
B&C Speakers
Part #294-6074
B&C Speakers
Part #294-6074
Model: DE985TN-8
Capable of high output low distortion midrange and high frequency response, the DE985TN 2" exit titanium compression driver from B&C Speakers is perfect for use in any speaker system built for extreme SPL. The 3" titanium diaphragm is optimized to deliver natural response from 500 to 18,000 Hz. The extremely strong neodymium motor includes a copper cap to ensure low distortion even when pushed to its limit.
  • 110 watts RMS (220 watts max) and 108.5 dB efficiency for incredible output capability
  • Extremely powerful neodymium motor lowers weight without sacrificing efficiency
  • 3" voice coil and titanium diaphragm delivers smooth and natural response
  • Copper shorting cap lowers inductance and minimizes distortion
For high output midrange and high frequency response, the powerful DE985TN 2" exit compression driver from B&C Speakers will deliver unbeatable reliability and extreme SPL. The large 3" diaphragm in has been completely redesigned to incorporate a bent edge voice coil former, new dome and surround geometry, and an optimized phase plug. These modifications combine to better control diaphragm displacement and deformations, resulting in lower distortion and a smoother higher frequency response above 10kHz. The powerful FEA optimized neodymium motor assembly keeps size and weight to a minimum without sacrificing overall efficiency and output capability. In addition, the pole piece includes a large copper cap to minimize inductance, improving high frequency response and keeping distortion as low as possible. The DE985TN is a powerful driver that will fit in with any high efficiency system designs.
Specifications: • Power handling: 110 watts RMS with minimum crossover of 800 Hz at 12 dB per octave • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-18,000 Hz • SPL: 108.5 dB 1W/1m • Dimensions: 5.2" diameter x 3.44" depth • Net weight: 5.51 lbs.
BrandB&C Speakers
ModelDE985TN-8
Part Number294-6074
UPC848864063492
Weight5.8
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)110 Watts
MONSTER DEAL
OF THE WEEK
$167.98 EACH
SAVE 20%
Dayton Audio RSS265HO-44 10" Reference Series HO DVC Subwoofer
