  • B&C DE750TN-8 2" Titanium Horn Driver 8 Ohm 4-Bolt
B&C Speakers
Part #294-615
B&C Speakers
Part #294-615
Model: DE750TN-8
B&C's flagship 2" driver, the DE750TN-8, features an all-titanium diaphragm for increased durability and accurate response.
  • 220 watt continuous program power capacity
  • 3" aluminum voice coil
  • Titanium diaphragm
  • Copper shorting cap for extended HF response
  • 107.5 dB sensitivity
  • 2" bolt-on format (4-bolt)
Your Price: $349.89
MSRP: $583.16
Save $233.27 (40%)
Order in the next 6 hr 5 min to ship today. Details
The B&C Speakers DE750TN-8 2" titanium HF driver is a world-class high frequency transducer that is capable of extreme output levels combined with incredible fidelity and musicality. A powerful ceramic ferrite magnet structure provides the high magnetic flux density required for the DE750TN's high efficiency, accuracy, and extended high frequency response. A copper cap on the pole piece reduces inductive losses and extends HF capabilities.
Specifications: • Power handling: 110 watts RMS/220 watts program above recommended crossover of 1 kHz/12 dB slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-18,000 Hz • SPL: 107.5 dB 1W/1m • Dimensions: 7.1" diameter x 3.4" depth • Net weight: 13.9 lb. • Replacement diaphragm available.
B&C Speakers' line of compression drivers is the result of a continuous research effort, dedicated to refine every component in the structure, and their overall balance. Diaphragms are made of titanium, mylar, or polyimide, in order to get the required results in efficiency and bandwidth. Their shape and structure is mathematically evaluated well before building the first prototype. Afterwards, their performance is tested with methods that range from modal analysis to laser vibrotomy.
All voice coils are of the edgewound ribbon type, and made of aluminum to reduce mass and achieve the best electro-acoustic performance. The magnet assembly is designed and optimized with up-to-date software for Finite Element Analysis (FEA) and complemented, where needed, by a copper cap to improve frequency extension and linearity. Equal care is taken in the design of phase plugs, whose role in enhancing performance and reducing distortion artifacts is critical for compression drivers. The precision and transparency of B&C compression drivers is constantly improved by the progress in acoustical modeling and simulation.
BrandB&C Speakers
ModelDE750TN-8
Part Number294-615
UPC844632001840
Weight14.3
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)110 Watts
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
