  • B&C 15DS115 15" Neodymium Subwoofer 8 Ohm
10 Questions, 19 Answers or
B&C Speakers
Part #294-6056
B&C Speakers
Part #294-6056
Model: 15DS115
B&C designed the 15DS115 15" high output subwoofer to produce more output and lower distortion than any other comparably priced driver. With high excursion, incredible efficiency, and excellent power handling, this driver has true earth shaking output capability.
  • 97 dB efficiency to ensure high output even with modest amplification
  • Double silicone spider keeps excursion linear even beyond rated Xmax
  • Neodymium magnet allows a very high force factor without excess weight
  • 4.5" four layer CCA voice coil allows high power handling and Bl
  • Aluminum shorting ring help control the voice coil for lower distortion
Your Price: $638.73
MSRP: $1,064.55
Save $425.82 (40%)
Order in the next 0 hr 44 min to ship today. Details
Only 3 In Stock
More due any day
B&C's 15DS115 15" subwoofer is the next evolution in high output subwoofer design. Using a new, longer, four layer aluminum voice coil to produce more energy in the gap, higher sensitivity, lower distortion, and better overall performance. The 15DS115 features a 40 mm long, 4.5" diameter (116 mm) copper clad aluminum wire voice coil. With a 1,600 watt AES power rating, 97 dB sensitivity, and over 16.5 mm of linear excursion, this high energy subwoofer is a significant step forward from similar models in the B&C range, even approaching the performance of their 6" voice coil alternatives.
BrandB&C Speakers
Model15DS115
Part Number294-6056
UPC848864058214
Weight28.8
Nominal Diameter15"
Bolt Circle Diameter13.94
Power Handling (RMS)1600 Watts
Power Handling (MAX)3200 Watts
Frequency Response35 to 1,000Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter4.5"
Resonant Frequency (Fs)33Hz
DC Resistance (Re)4.9Ω
Voice Coil Inductance (Le)4.5mH
Mechanical Q (Qms)5.2
Electromagnetic Q (Qes)0.18
Total Q (Qts)0.17
Compliance Equivalent Volume (Vas)3.32ft³
BL Product (BL)38.7T·m
Diaphragm Mass Inc. Airload (Mms)254g
Maximum Linear Excursion (Xmax)16.5mm
Surface Area of Cone (Sd)855cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter15.47"
Baffle Cutout Diameter13.94"
Depth7.83"
Vented Volume2.5ft³
Vented F335.4Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
