  • Axxess AX-MLOC-HD1 2-Ch 80W Line Output Converter
1 Question, 1 Answer or
Axxess
Part #265-5815
Axxess
Part #265-5815
Model: AX-MLOC-HD1
Axxess' 2-channel adjustable MLOC-HD1 connects to a mobile audio head unit's speaker-level output and converts it to line-level RCA output, for use with line-level only mobile audio electronics like equalizers, active crossovers, and amplifiers. It also features a 12V trigger; Great for adding powered subwoofers to OEM stereos! 80W/channel.
  • Stereo 2 channel input
  • 80 watts max per channel
  • Stereo RCA outputs
  • Infinitely adjustable gain for each channel
  • 12 volt signal auto sense turn on
  • Additional speaker pod harnesses included
Your Price: $28.00
MSRP: $42.00
Save $14.00 (33%)
The adjustable MLOC-HD1 two-channel speaker-level to line-output converter (also called a high-to-low adapter), from Metra, allows for the installation of line-level mobile audio electronics, such as amplifiers and active crossovers, into systems without a line-level signal by using the head unit's speaker output. Line level audio can be output via stereo RCA.
Great for adding powered subwoofers to OEM systems, the MLOC-HD1 is able to auto sense audio input and generate a 12V signal to turn on additional aftermarket accessories via EIA standard wiring. Included are two speaker pod harnesses for 2014-2018 Harley-Davidsons.
BrandAxxess
ModelAX-MLOC-HD1
Part Number265-5815
UPC086429339273
Weight10.2
