  • Axxess AXGLI-R 2-Ch Ground Loop Isolator
Axxess
Part #266-007
Axxess
Part #266-007
Model: AXGLI-R
Ground loops create noticeable hum in home audio systems, and alternator whine (also known as engine noise) in car audio systems. Eliminate both with the Axxess AXGLI-R ground loop isolator, without crosstalk distortion. Both male and female connection harnesses are included.
  • Eliminate system hum in home audio systems
  • Remove alternator whine in car audio systems
  • Lowers the noise floor without crosstalk interference
Your Price: $15.98
MSRP: $21.99
Save $6.01 (27%)
Quantity:Qty: 1-3 $15.98/ea
Quantity:Qty: 4+$15.48/ea
Order in the next 4 hr 28 min to ship today. Details
The Axxess AXGLI-R is designed to eliminate ground loop noise (usually referred to as hum) and alternator whine from two RCA line-level audio channels. Great for the car, and even for the home, where amplifiers and other electronics (such as crossovers and equalizers) are separate of the source. The detachable and interchangeable RCA input and output harnesses with one set of males and one set of females for use at either the head unit or amplifier without gender changing connectors. Axxess' AXGLI-R does its job without the crosstalk interference (left and right channels bleeding together) common in other ground loop isolators.
BrandAxxess
ModelAXGLI-R
Part Number266-007
UPC086429395538
Weight0.25
