  • Axxess AXDCT-2 2-Ch 80W Speaker to Line Level Output Converter w/Trigger
Axxess
Part #266-005
Axxess
Part #266-005
Model: AXDCT-2
Axxess' 2-channel adjustable AXDCT-2 connects to a mobile audio head unit's speaker-level output and converts it to line-level RCA output, for use with line-level only mobile audio electronics like equalizers, active crossovers, and amplifiers and features a 12V trigger.
  • 40W x 2 power handling
  • Converts speaker output to line-level output
  • Can also be used with home audio systems
  • Small size and easy to install
  • Two output adjustments for gain matching
  • 12 VDC, 500 mA output for amplifier turn-on
Your Price: $20.89
MSRP: $28.99
Save $8.10 (28%)
Out of Stock
The adjustable Axxess AXDCT-2 two-channel speaker-level to line-level converter (also called a high-to-low adapter) allows for the installation of line-level mobile audio electronics, such as amplifiers and active crossovers, into systems without a line-level signal by using the head unit's speaker output. Great for adding powered subwoofers to OEM systems. Handles up to 40 watts per channel and features a gain level adjustment (up to a 6:1 power step-down) for each channel for fine-tuning. The AXDCT-2 features a 12V input to activate a 12 VDC, 500 mA output for turning remote amplifiers on.
BrandAxxess
ModelAXDCT-2
Part Number266-005
UPC086429395910
Weight0.25
