  • Aurasound AST-2B-4 Pro Bass Shaker Tactile Transducer
AuraSound
Part #299-028
AuraSound
Part #299-028
The Aurasound AST-2B-4 Pro Bass Shaker literally sends sonic vibrations through the material to which it is attached, enabling you to feel the earth-shaking bass from your music, movies, or video game soundtracks.
  • Pro version bass shaker handles 50 watts for higher visceral experience
  • More driving force than a standard shaker, to bring your theater chairs to life!
  • Feel earth shaking bass from your music videos and games like the pros
  • Add deep bass where space is limited, like in smaller vehicles
  • Minimal distortion while enhancing the bass energy delivered from your stereo
  • Utilize conventional series parallel wiring configuration for larger surface areas
Your Price: $79.98
MSRP: $102.99
Save $23.01 (22%)
Quantity:Qty: 1-3 $79.98/ea
Quantity:Qty: 4+$76.98/ea
Are you getting all the bass you want? Not yet!
The Aurasound AST-2B-4 Pro Bass Shaker—also known as a butt shaker, or tactile transducer—works on the principle that low bass is mostly felt and not heard. Experience earth-shaking bass from all of your media: music, computer, movies, or video games. The Aurasound Pro Bass Shaker was designed originally for automotive applications in order to produce big car subwoofer bass without taking up valuable space in the vehicle's trunk. Pro Bass Shakers are ideal for convertibles and sports cars, or wherever installing a large car stereo subwoofer is not practical. They can also be used in the home to make your own movie or video game chair.
Key Specs:
  • Power Handling (RMS): 50W
  • Power Handling (MAX): 100W
  • Impedance:
  • Useable Frequency Response: 20-80 Hz
  • Force Peak: 30 lbs. per ft.
  • Dimensions: 6.2" dia. x 2.5" H
Download Specs
Feel the earth-shaking bass from your music, movies, or video game soundtracks
Easy to install, so you'll be shaking in no time
An Aurasound Bass Shaker simply mounts to the floorboard under the seat or to the bottom of a chair to send vibrations through the structure, enabling you to feel awesome bass. Each Pro version bass shaker handles 50 watts of power and produces more driving force than a standard shaker. Shakers connect to an amplifier like ordinary speakers do, so it's easy to use an array for larger surface areas like couches or love seats by utilizing a conventional series-parallel wiring configuration. Aurasound part number AST-2B-4. Sold and boxed individually and also available packed 16 units per case.
Install by Robert C.
Sub-bass that travels through solids instead of air
Want to feel your music? Connect a Pro Bass Shaker and experience every thump, thrust, and shake...the way bass sound was originally intended. Aurasound's patented technology preserves the sound pressure levels so there's no distortion while enhancing the bass energy delivered from your stereo. We're taking surround sound to another level...
Get all of the excitement your media can deliver
Bass shakers have a variety of uses from home theaters to gaming rigs as well as commercial applications such as arcade games. Easily add low end rumble to any entertainment environment with the use of bass shakers
Install by Joey M.
Bass Shakers from Aurasound Systems add the exciting dimension of feeling to the sights and sounds of video arcade games, movies, stage shows, and multimedia attractions! By actively converting bass sound waves into spine-tingling vibrations, Bass Shakers turn entertainment into a "moving experience"!
Bass Shakers bring coin-operated video arcade games to life by transforming a game's audio output into body-pulsing tactile sensations. With Bass Shakers installed into arcade seats or floor platforms, players can feel everything from a fighter's punch to the roaring engine of a Formula One race car.
In movie theaters, the action jumps off the screen, the soundtrack comes to life, and the entire experience is intensified. Bass Shakers hook up like a speaker and mount directly to a standard theater seat. Installed in seats, tables, booths, floors of showrooms, and theaters, Bass Shakers provide audiences with a more complete entertainment experience. Las Vegas stage extravaganzas, hit Broadway musicals, and rockin' concerts virtually jump off the stage into the audience. Bass Shakers are ideal for bringing music, on-stage special effects, and laser shows to life.
Add value, thrills, and total satisfaction
For commercial applications, Bass Shakers turn up the revenue potential of any entertainment experience. Thanks to low purchase, installation, and maintenance costs, the Bass Shaker is a virtual winner in the race to provide affordable upgrades and enhancements to existing facilities.
Pair With The Perfect Amp
We have a vast selection of amps to drive your bass shakers including sub amps, plate amps, and amps with built in digital signal processing.
Dayton Audio APA150
Dayton Audio's versatile APA150 power amplifier delivers 75 watts per channel in its full-range stereo configuration, or 150 watts into 8 ohms when in bridge-mono mode. A built-in, switchable low-pass filter also makes the APA150 a great subwoofer amp!
Shop APA150
Dayton Audio BSA-200
Dayton Audio's BSA-200 bridgeable stereo amplifier is a perfect solution for bass shaker or subwoofer installs. The compact and powerful design makes the BSA-200 a versatile amplifier for home theater or gaming applications.
Shop BSA-200
Dayton Audio SA1000
Dayton Audio's SA1000 mono subwoofer amplifier provides nearly a kilowatt of clean, solid power to your home theater or music playback system. The is an ideal partner for high-performance subwoofer speaker systems.
Shop SA1000
Dayton Audio SPA250
Engineered to provide flexibility, ample power, and reliability, the Dayton Audio SPA250 delivers high fidelity subwoofer amplification which is tailored for home audio and home theater audio systems. Ideal for speaker building enthusiasts, the SPA250 can also breathe new life into many powered subs where the amp has failed.
Shop SPA250
Dayton Audio SPA300-D
The Dayton Audio SPA300-D high-efficiency subwoofer plate amp packs big-amp features into a compact chassis. A Class-D topology makes it small, but with the same output capability as a traditional amplifier topology. We've included everything that you need to connect the amp to your system and get maximum performance!
Shop SPA300-D
Dayton Audio SPD250DSP
The Dayton Audio SPA250DSP digitally processed plate amplifier offers an elite level of control over your entire system (i.e. subwoofer and mains). This unique amplifier allows you to fine tune your system's low frequency performance, and at the same time high pass to your mains (or satellites) protecting them from damage due to over excursion.
Shop SPA250DSP
All-in-one bundles
If you are looking for an all-in-one bass shaker solution, we have created bundles perfect for any application. Get the bass shakers with an amp that has the power to get the best performance and deliver that low end you've been missing.
Shop Bass Shaker Bundles
BrandAuraSound
ModelAST-2B-4
Part Number299-028
UPC844632045127
Weight3.25
ApplicationLow Frequency Bass Shaker
Power Handling (RMS)50 Watts
