  • Audyn True Copper Cap 0.22uF 630V Copper Foil Capacitor
Audyn
Part #027-151
Audyn
Part #027-151
Choose Audyn's 0.22 µF True Copper Cap, German-made capacitor for pure signal filtering as a bypass capacitor for speakers or for use in replacing capacitors in the signal path of existing high-end passive crossovers.
  • Designed for the most transparent sound possible
  • Oxygen-free, non-inductive copper foil design with polypropylene dielectric
  • Seven 0.5 mm Tritec tinned wire leads for flexibility and a larger surface area for soldering
  • Precision made in Germany with 2% tolerance
  • High 630 VDC voltage rating
Your Price: $49.80
MSRP: $93.99
Save $44.19 (47%)
Quantity:Qty: 1-9 $49.80/ea
Quantity:Qty: 10+$44.50/ea
Order in the next 18 hr 57 min to ship today. Details
46In Stock
Audyn's True Copper Cap line of capacitors is German-made to an exacting 2% tolerance using ultra-pure OFC (oxygen free copper) foil electrodes and a polypropylene dielectric. This combination of capacitor materials provides a clean, neutral, "signal-in is signal-out" sound. No strange mixtures of various materials or, as the manufacturer says, "fairylike oils". The use of pure copper also reduces inductance for the greatest possible extension.
European users of the Audyn True Copper Cap capacitors regard them as spatially remarkable, great for imaging, and naturally balanced. Extract the best possible performance from your speakers' drivers, and hear everything on high resolution recordings. Audyn's True Copper Cap capacitors are also great for upgrading capacitors in the signal path of existing high-end passive crossovers.
Specifications: • Value: 0.22 µF • Dimensions (diameter x length): 25 x 35 mm • Voltage rating: 630 VDC.
BrandAudyn
Part Number027-151
UPC848864015378
Weight0.1
Capacitance0.22 uF
Tolerance2%
Voltage Rating600V
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
