  • Audtek SSW-4 Speaker Selector Switch Impedance Matching 1 In 4 Out
Audtek Electronics
Part #300-971
Model: SSW-4
The Audtek SSW-4 low-profile speaker selector box allows you to distribute a stereo amplifier to four separate zones. Front plate zone selection buttons make it easy to turn zones on and off. Built-in selectable protection circuit ensures total impedance does not drop below unsafe operating levels.
  • Distribute a stereo speaker level signal across up to four listening areas
  • Easily turn zones on and off from ergonomic front panel zone selection buttons
  • Selectable protection circuit to ensure total impedance does not drop below 5 ohms
  • High-quality push-pin terminals accept up to 14 AWG for long cable runs
Your Price: $34.98
MSRP: $34.99
Save $0.01 (0%)
Order in the next 4 hr 8 min to ship today. Details
The Audtek SSW-4 low-profile speaker selector box allows you to distribute a stereo amplifier to four separate zones. Accepting stereo speaker-level (amplified) signal, the SSW-4 provides up to 140 WPC for your zones. Front plate zone selection buttons make it easy to turn zones on and off.
Including a manually activated impedance protection circuit that can be turned ON, the SSW-4 prevents the impedance to your amplifier from dropping below an unsafe level of 5 ohms. The protection circuit ensures proper performance regardless of the number and impedance ratings of your speakers. The protector switch can also be turned off when used as part of a planned system of impedance matching volume controls, allowing you to get most out of your amplifier.
Output zones: 4 x Stereo
Protection circuit resistors: 2 x 10 ohm/15 WPC
Power handling (protection on): 70 WPC
Power handling (protection off): 140 WPC
Input connections: 1 x high-level with push-pin terminals (up to 14 AWG)
Output connections: 4 x push-pin terminals (up to 14 AWG)
Dimensions: 8.5" x 4.4" x 1.9"
BrandAudtek Electronics
ModelSSW-4
Part Number300-971
UPC848864063096
Weight2.6
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
