  • Audtek 3 ft. Pro Grade Ultra HD HDMI Cable 4K@60 Hz HDR YCbCr 4:4:4 CL2 18 Gbps
Audtek Electronics
Part #180-1302
Audtek Electronics
Part #180-1302
Model: CG3
Enjoy the best resolution possible, up to 2160p, with Audtek's Pro Grade Ultra HD HDMI 2.0 cable. It transfers audio, video, and data signals up to 18 Gbps - supporting 4K Ultra HD content at 60 Hz.
  • Rated HDMI 2.0 to deliver the most bandwidth for current and future technologies
  • Supports High Dynamic Range (HDR) and 4K@60 Hz at 16-bit color depth (4:4:4) compatibility for striking video imagery
  • CEC Extensions, dual-view, and 21:9 aspect ratio support
  • HDCP 2.2 compliance for full 4K compatibility
  • Supports up to 2160p resolution
  • Certified CL2 and UL for in-wall installations
Your Price: $3.19
MSRP: $4.99
Save $1.80 (36%)
Quantity:Qty: 1-9 $3.19/ea
Quantity:Qty: 10+$2.98/ea
592In Stock
Don't let your HDMI cable be the weak link in your 4K Ultra HD home theater. Use the Audtek Pro Grade Ultra HDMI 2.0 cable to ensure that you get the full potential of 4K UHD content when available. Trust this HDMI cable to transfer 18 Gbps transmission bandwidth from your source without downgrading your video signal.
This cable supports 4K@60 Hz at 16-bit color depth (4:4:4) so no matter what TV you have, you will realize its full potential with this HDMI cable. Other features included with this high speed is Ethernet compatibility, an audio return channel, 30 AWG wires, and improved 3D support.
BrandAudtek Electronics
ModelCG3
Part Number180-1302
UPC848864062419
Weight0.15
Cable Length3feet
Cable TypeHDMI Male to Male
Jacket ColorBlack
Throughput18 Gbps
Wire Gauge30 AWG
Special FeaturesCL2 Rated
