  • Audtek 100 ft. 14 AWG Direct Burial Outdoor Speaker Wire-CL2 Rated-Oxygen Free Copper (OFC) Black
CLEARANCE Audtek 100 ft. 14 AWG Direct Burial Outdoor Speaker Wire-CL2 Rated-Oxygen Free Copper (OFC) Black
1 Question, 2 Answers or
Audtek Electronics
Part #100-474
Model: BCSW-100
This wire is perfect for outdoor speakers, low voltage lighting, and many other outdoor or direct burial applications. The cable features a specially formulated black PVC jacket that is UV resistant and the inner layer water blocking tape helps provided protection against water damage.
  • Made specifically for outdoor use, above or below ground
  • Each audiophile grade conductors contain 105 strands of oxygen free copper
  • High strand count for better signal transfer and flexibility
  • Perfect for outdoor speakers, low voltage lighting, and other outdoor or direct burial applications
  • Parallel/twist conductors resist interference and enables better current flow
  • CL3 flame rated for in-wall installations
  • ETL listed and CE certified for contract installations
CLEARANCE $41.99
MSRP: $69.99
Save $28.00 (40%)
Order in the next 0 hr 8 min to ship today. Details
4In Stock
This wire is perfect for outdoor speakers, low voltage lighting and many other outdoor or direct burial applications. The cable features a specially formulated black polyethylene jacket that is UV resistant and an inner layer tape that provides protection against water damage. Use moisture proof sealing tape, heat shrink, or silicon products around the conductors when the jacket is removed. Audiophile grade conductors in every cable contain 105 strands of oxygen free copper each. The high strand count provides improved skin effect. The diameter of the cable with the two conductors and the polyethylene black jacket is 0.283" (7.2 mm).
Specifications: • Length: 100 ft. • Outer Diameter: 0.283" (7.2 mm) • Jacket thickness: 0.023" (0.6 mm) • Jacket material: PVC • Flame rating: CM, CL3 • Temperature rating: -4° to 140° F (-20° to 60° C) • Voltage rating: 300V • Capacitance between conductors @ 1 kHz: 24pF/ft. Nom. • DC resistance per conductor @ 68° F: 13.7 Ohms/KM’ Nom.
BrandAudtek Electronics
ModelBCSW-100
Part Number100-474
UPC848864069777
Unit of MeasureRolls
Weight5.2
Conductors2 Conductor
Jacket ColorBlack
Wire Gauge14
Special FeaturesDirect Burial
