  • Parts Express Audiophile Locking RCA Connector 2 Pair
CLEARANCE Parts Express Audiophile Locking RCA Connector 2 Pair
Part #091-1065
Part #091-1065
Audiophile connectors feature the same high performance features found in exotic connectors at a price that you can afford. Four connectors included.
  • 24k gold plated construction
  • Split center pin for maximum contact
  • Set-screw cable strain relief
  • 8.3 mm cable entry
  • Cap screws on even after wire has been connected for convenience
Audiophiles demand connectors that perform as well as they look, but that doesn't mean the connector should be priced out of reach for the everyday audio enthusiast. Audiophile connectors feature the same high performance features found in exotic connectors at a price that you can afford. After assembly simply slip the connector onto the RCA jack and tighten the shell to hold the connector securely. Four connectors included.
Features and Specifications: • 24k gold plated construction • Solder-type center contact • Split center pin for maximum contact • Polished platinum barrel • Set-screw cable strain relief • 8.3 mm cable entry • Contact plating: gold • Shell material: brass • Finish: black chrome • Sold per: 2 pairs • Entry hole: 8.3 mm • Termination style: solder.
Part Number091-1065
UPC844632064982
Weight0.3
GenderMale / Plug
Mounting TypeCable Mount
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
