  • Audio-Technica AT-VM95ML/H Microlinear Stereo Cartridge with Premounted Headshell
Audio-Technica
Part #240-5645
Audio-Technica
Part #240-5645
Model: AT-VM95ML/H
The Audio-Technica VM95ML/H microlinear stero cartridge with premounted headshell delivers a powerful 3.5 mV output with excellent channel separation and low distortion. The durable, low-resonance housing includes threaded inserts that enable the cartridge to be mounted to the headshell with just two screws with no nuts required.
  • VM dual magnet cartridge with 2.2 x 0.12 mil Microlinear stylus
  • Aluminum cantilever
  • Specially wound coils increase output voltage
  • Durable low-resonance polymer housing
  • Threaded inserts in cartridge body enable cartridge to be mounted to headshell with just two screws, no nuts or washers required
  • Compatible with any AT-VMN95 replacement stylus
  • Universal 1/2" mount headshell for 4-pin turntable cartridges
Your Price: $199.00
Order in the next 0 hr 56 min to ship today. Details
The AT-VM95ML/H combo kit includes the AT-VM95ML dual moving magnet cartridge premounted on the AT-HS6BK headshell.
This VM95 Series cartridge with 2.2 x 0.12 mil Microlinear stylus fits half-inch mount turntables. The cartridge offers excellent channel separation and low distortion for outstanding tonal quality. The durable, low-resonance housing includes threaded inserts that enable the cartridge to be mounted to the headshell with just two screws with no nuts required. And since all VM95 Series share the same body, the stylus can be replaced with any of the six interchangeable AT-VMN95 replacement styli.
The AT-HS6 is a universal 1/2"-mount headshell for 4-pin turntable cartridges. It features an ultra-lightweight (9 g) aluminum die-cast body to keep vibration to a minimum for accurate playback both for DJs and causal listeners. A finger lift enables simple, precise stylus placement. The headshell is also equipped with gold-plated lead wires for lossless signal transmission and comes with mounting screws for connecting the headshell to a cartridge.
Frequency response: 20-25,000 Hz
Channel Separation: 23 (dB at 1 kHz)
Vertical tracking angle: 23°
Vertical tracking force: 1.8-2.2 g (2.0 g standard)
Stylus construction: Bonded round shank
Recommended load impedance: 47 kohms
Coil impedance: 3.3 k ohms (1 kHz)
DC resistance: 485 ohms
Coil inductance: 550 mH (1 kHz)
Load capacitance: 100 to 200 pF
Output: 3.5 mV (1 kHz, 5 cm/sec.)
Channel balance: 1.5 dB (1 kHz)
Stylus shape: 2.2 x 0.12 mil Microlinear
Cantilever: Aluminum pipe
Mount: Half-inch
Replacement stylus: AT-VMN95ML
Accessories included: Two 11 mm installation screws, two 8 mm installation screws, two washers, nonmagnetic screwdriver
Dimensions:21.2 mm (0.83") H × 21.4 mm (0.84") W × 62.4 mm (2.46") D
Weight: 15.5 g (0.55 oz)
BrandAudio-Technica
ModelAT-VM95ML/H
Part Number240-5645
Weight0.15
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
