  • AtlasIED PA601 60W Power Amplifier
Atlas Sound
Part #242-920
Atlas Sound
Part #242-920
Model: PA601
The PA601 is the perfect choice for distributed background music (BGM) systems when the requirement is simple amplification without MOH or advanced mix functionality.
  • Simple clean power in a compact package
  • One channel at 60W into 70.7V, 100V, and 8 ohm loads
  • One balanced phoenix or unbalanced RCA input
  • Unique loudness contour switch (+4 dB @ 100 Hz and 8 kHz)
  • UL Listed/Standard 60065; RoHS 2006 compliant
Your Price: $458.99
MSRP: $571.99
Save $113.00 (20%)
Specifications: • Power output: 60 watts RMS (8 ohms, 1 kHz, 0.5% THD) • Frequency response: 50 Hz-20 kHz • Speaker outputs: 4 ohm, 70.7V, and 100V • Rack spaces: 2U high, 1/2U wide • Optional AARMK2-5 rack mount kit for one or two PA601 amplifiers sold separately • Net weight: 14 lbs. • Dimensions: 8.27" W x 3.66" H x 14" D • Mfg. #PA601.
BrandAtlasIED
ModelPA601
Part Number242-920
UPC612079183234
Weight14
Power Output (RMS @ 70V)51W to 100W
Weight Range10 to 19 lbs.
