  • Amiga MT Tower Speaker Kit with Knock-Down Cabinet
Part #300-7124
Part #300-7124
Another popular design by Paul Carmody, the Amiga 2-way tower kit has a small footprint but produces a big sound. This kit has become known as a boutique Hi-Fi killer. This kit includes almost everything you need to build a single compact tower speaker, including: a knock-down cabinet, drivers, crossover components, hardware, binding posts, and damping material.
  • The Amiga has a detailed yet relaxed sound with surprising low frequency extension
  • Remarkably flat response, ±2.5 dB from 35-20,000 Hz
  • CNC cut MDF cabinet panels make the enclosure easy to assemble with minimal tools
  • Designed and fine-tuned by expert designer Paul Carmody
Your Price: $239.98
MSRP: $306.99
Save $67.01 (22%)
Known as a boutique Hi-Fi killer, the Amiga 2-way Tower kit includes almost everything you need to build a single compact tower speaker, including: a knock-down cabinet, drivers, crossover components, and damping material.
Features:
  • The Amiga has a detailed yet relaxed sound with surprising low frequency extension accurately reproduces music as the artists intended it to be heard
  • Denovo Audio CNC cut MDF cabinet panels make the enclosure easy to assemble with minimal tools
Customer Comments:
" I was pleasantly surprised how wonderful these sound..." -Ryan C. ⋆⋆⋆⋆⋆
"..a sub is almost most likely not needed for most music. A great project (with) a very satisfying end result." -Josh C. ⋆⋆⋆⋆⋆
"The CNC precision on the kit was literally flawless. This was my first speaker build, but they sound incredible" -SEAN S. ⋆⋆⋆⋆⋆
"...The sound from these speakers is fantastic... The definition is incredible. The sound is very well balanced." -Rob B. ⋆⋆⋆⋆
Meet the Designer:
Paul Carmody
A self-admitted speaker addict, Paul advocates learning the science behind loudspeaker design.
Customer Projects:
Kit Components:
Part #QTY.Description
027-4241Dayton Audio DMPC-6.8 6.8uF 250V Polypropylene Capacitor
027-402
1Dayton Audio DMPC-0.22 0.22uF 250V Polypropylene Capacitor
027-4261Dayton Audio DMPC-8.2 8.2uF 250V Polypropylene Capacitor
255-2241Jantzen 1950 0.40mH 18 AWG Air Core Inductor
255-2661Jantzen 1063 2.0mH 18 AWG Air Core Inductor
255-0301Jantzen 1204 0.35mH 20 AWG Air Core Inductor
004-5.11Dayton Audio DNR-5.1 5.1 Ohm 10W Precision Audio Grade Resistor
004-2.41 Dayton Audio DNR-2.4 2.4 Ohm 10W Precision Audio Grade Resistor
004-21 Dayton Audio DNR-2.0 2.0 Ohm 10W Precision Audio Grade Resistor
264-10201Peerless by Tymphany DX25TG59-04 1” Fabric Dome Tweeter
295-364
1 Dayton Audio RS180S-8 7” Reference Shielded Woofer 8 Ohm
260-387
1 Port Tube 2” ID Adjustable
260-520
2 Sonic Barrier 1/2” Acoustic Foam w/PSA 18” x 24”
-1 Denovo Audio Amiga Tower Speaker Knock-Down Cabinet
  • Power: 70 watts RMS/140 watts max
  • Frequency response: 34 - 20,000 Hz
  • Impedance: 8 Ohm
  • Sensitivity: 84 dB 1W/1m
  • Dimensions: 34" H x 8" W x 11" D
ModelAmiga
Part Number300-7124
UPC848864034737
Weight48.62
Cabinet Dimensions (HxWxD)34" x 8" x 11
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
Configuration2-way
Input Rating8 ohm
Speaker TypeFloor Standing
Woofer Diameter7"
