  • Acry-Tech DuraTex White 1 Gallon Spray Grade Speaker Cabinet Coating
1 Question, 2 Answers or
Acry-Tech Coatings
Part #260-119
DuraTex Spray Grade Speaker Cabinet Coating is a water-based, protective finish designed to enhance and safeguard speaker cabinets, road cases, and equipment enclosures. It offers a durable, abrasion-resistant, and water-resistant textured surface that can be easily applied with a roller, providing both aesthetic appeal and long-lasting protection.
  • Water-based, non-toxic formula for safer, eco-friendly use
  • Water-resistant finish protects against moisture damage​
  • Abrasion-resistant surface withstands wear and tear​
  • Adheres to wood, MDF, and more without special primers
  • Ideal for speaker cabinets, road cases, and other equipment surfaces
  • Low-VOC, eco-friendly formulation for safe application​
  • No need for special primers to achieve a long-lasting, durable finish
Your Price: $107.98
MSRP: $154.99
Save $47.01 (30%)
What makes DuraTex unique?
The water-based nature of Duratex means it's safer for the environment and the people using it.
​With over 40 years of experience in water-based coating systems, Acry-Tech Coatings has encountered a vast array of surfaces, enabling us to assist customers in determining the most effective solutions for their needs. ​
What problem is DuraTex solving?
Duratex's durability and the level of protection it provides make It a cost-effective choice over the long term. Extending the materials' life and reducing maintenance needs offer significant savings.
DuraTex Protective Coating is the ideal choice for tough, long-lasting surface protection. This non-toxic, water-based coating is specifically formulated for speaker cabinets, road cases, and other equipment that needs a rugged, scratch-resistant, textured finish. Whether you're a seasoned professional or a do-it-yourself hobbyist, DuraTex is designed for easy application and consistently delivers a high-quality, professional look.
DuraTex gives you the flexibility to achieve the exact aesthetic your project demands without compromising strength or durability. Its impact-resistant composition shields your equipment from wear and tear, even in high-stress environments where gear is handled frequently.
Enhance your gear with the proven reliability of DuraTex—an ideal finish for speakers, enclosures, cases, and more. DuraTex is formulated to provide a tough, long-lasting finish that preserves both function and appearance over time. When you choose DuraTex, you choose performance, protection, and a professional finish in one easy-to-use product.
DuraTex's exceptional coverage allows you to complete large projects efficiently, with up to 200 square feet of coverage per gallon.
Technical Data
  • V.O.C.: 0.46#/Gal. (55g/L) as packaged
  • Solids by Weight: 44% / 63%
  • Solids by Volume: 40% / 51%
  • Viscosity:
    -Roller Grade=25Kcps,
    -Spray Grade=15Kcps
  • Wt per Gallon: 9.0# / 11.5#
  • Cleanup: Soap and Water on fresh material, and Xylene or Toluene on dried material
HMIS Ratings
  • HEALTH -1
  • FLAMMABILITY – 0
  • REACTIVITY – 0
  • PERS. PROT.: HANDLING B
  • APPLICATION G
Surface Preparation
All substrates must be clean and dry with no oils, silicones, waxes or other contaminants. Fill holes in wood substrate with Elmer’s Carpenter’s Color Change Wood Filler to prevent potential adhesion issues. Stay away from certain wood fillers that stay soft & rubbery when they are fully cured because there is a chance that DuraTex may not adhere to these types of fillers. DO NOT USE A POROUS TYPE OF WOOD FILLER AS THESE COULD CAUSE POTENTIAL CRACKS IN THE DURATEX COATING. We recommend doing a spot adhesion test to ensure there are no issues with the DuraTex coating. Please contact us with any questions.
Application
By ROLLER: Apply spray grade with our texture foam roller to evenly coat the surface if a textured surface is desired. A heavy first coat followed by a lighter second coat will give a milder texture. A heavy second coat will produce a more aggressive texture. Adding a small amount of water to the product will reduce the texture profile and can provide more of an orange peel texture. If a smooth finish is desired, use a smooth foam roller to apply and be mindful of any roller nap overlap marks.
By SPRAY: Apply spray grade by Hopper Gun, Pressure Pot HVLP or airless spray system in a complete even coat to the entire surface to completely seal and protect the surface. Once the base coat is dry, apply a spray texture coat by lowering the air break-up pressure. Spray pressures will be dependent on the type of spray equipment being used. Test the spray application technique first on a piece of cardboard and note pressure settings needed to accomplish the finish desired. Typical pressure pot base coat application uses only 15# of fluid pressure and 30# of air pressure. Texturing uses 20# of fluid pressure and only 5-10# of air pressure.
Higher air pressure = smaller dots. Lower air pressure produces larger dots. Higher fluid pressure + Higher air pressure produces a smoother, orange peel surface. Multiple color spatters create a “stone look” finish!
Allow all materials to dry thoroughly through air drying or forced drying in a baking oven. Do not exceed temperatures of 150°F for drying. Heating speeds up the curing process of DuraTex® but normal air drying will accomplish the same finished result over time. (Oven heating is optional, but facilitates rapid production throughput.) Do not apply this product to damp surfaces or when surface temperature is or will be below 60°F. and when Relative Humidity is above 70%.
Storage
To store containers that have been previously opened, spray a fine mist of water onto the coating surface in the container before resealing the lid. This raises humidity levels in the container and can help prevent the product drying or skinning over in the container.
Cautions
KEEP FROM FREEZING. USE ONLY WITH ADEQUATE VENTILATION. WEAR NIOSH APPROVED ORGANIC VAPOR CARTRIDGE MASK WHEN APPLYING OR SANDING IN CONFINED AREA. DO NOT TAKE INTERNALLY. CLOSE CONTAINER AFTER EACH USE. KEEP OUT OF THE REACH OF CHILDREN! AVOID EYE AND SKIN CONTACT. WEAR GOGGLES. SHELF LIFE AT LEAST ONE YEAR WHEN STORED AT 75°F IN ORIGINAL UNOPENED CONTAINERS.
BrandAcry-Tech Coatings
Part Number260-119
UPC810094630102
Weight10
