ART SLA4 Power AmplifierOffering superb sound quality, the ART SLA-4 studio linear power amplifier delivers the clean power you need for any professional audio application including project or professional studio environments or commercial sound installations. The SLA-4 is a true four-channel amplifier in a single rack-space that can be switched easily from multi-channel, stereo and bridged mono modes. Separate mode switches allow you to bridge channels 1 and 2, or channels 3 and 4, or both channel pairs. This maximizes flexibility by allowing the amp to be configured for best utilization in 2, 3, or 4 channel applications. Designed for long-term reliability in any audio application, the SLA-4's output is fully protected from short circuits. An ultrasonic network decouples RF from the output and helps keep the amplifier stable with reactive loads. The SLA4 is stable into loads as low as 2 ohms (stereo mode) or 4 ohms (bridged mode) making it ideal for virtually any installation application or complex system configuration. The SLA-4 features SmartFan™, an advanced, thermal dependent fan assisted convection cooled system. The SmartFan system is dependent upon the internal ambient temperature of the unit, and runs at high or low levels depending on the amplifier's cooling needs.
1/4" TRS and Euroblock balanced inputs as well as multi-way output binding posts are ensure the SLA4 can be quickly and easily tied in to any system without modification. A simple to install tamper proof cover is included.
Offering a superb level of sound quality, ART power amplifiers feature clean, powerful circuitry, along with a straightforward user interface. They are an excellent choice when a robust amplifier is necessary to deliver the power you need for professional and project studio monitoring. ART power amplifiers may be used in a wide variety of project and professional studio environments. Self-contained in a steel and aluminum enclosure, these units are designed for many years of reliable performance.
Specifications: • Frequency response: 10 Hz to 40 kHz • Bridged output power: 16 ohms 2 x 200 watts/channel RMS, 8 ohms 2 x 280 watts/channel RMS • CMRR: >60 dB (typical @ 1 kHz) • Damping factor: >100 • Frequency response: 10 Hz to 40 kHz, +/- 0.5 dB.
