  • ADJ AIR314 Airstream 4 Channel Wi-Fi Switch Bar
CLEARANCE ADJ AIR314 Airstream 4 Channel Wi-Fi Switch Bar
ADJ
Part #244-4608
ADJ
Part #244-4608
Model: AIR314
4-Channel WIFI switch BAR. Control four outlets On/Off of your lighting wirelessly using the Airstream Wifi iOS app for iPhone or iPad. Tripod stand, lighting fixtures and mobile device sold separately.
  • Wirelessly control four outlets
  • One device controls your lights and mounts then to a light stand for easy assembly
  • Built-in WiFi
CLEARANCE $99.00
MSRP: $239.95
Save $140.95 (59%)
2In Stock
The ADJ AIRSTREAM WIFI BAR is a wireless device that allows your iPhone or iPad to control the four outlets (ON/OFF) on the AIRSTREAM WIFI BAR. The AIRSTREAM WIFI BAR creates a private standalone WiFi network, no existing network infrastructure required. After connecting the AIRSTREAM WIFI BAR device to the AIRSTREAM WIFI iOS app wireless network, users can wirelessly switch the four outlets ON and OFF manually or automatically. The wireless frequency is 2.4 GHz and it will coexist in busy RF environments alongside technologies like Bluetooth and other WiFi networks. The AIRSTREAM WIFI BAR is the ideal solution for mobile entertainers, nightclubs, bars, production events or for any event where you do not want data or power cables to be seen. The AIRSTREAM WIFI BAR includes a WiFi antenna, 4 Edison output sockets, power indicator LED, primary/secondary switch and an on/off switch.
Power Consumption: 7.7W
Voltage: AC 100 ~ 240V, 50/60Hz
Total Max. Loading: 15A / 1,800W
Single Channel Loading: 8A / 960W
Wifi Frequency: 2.4GHz 802.11b
Working Humidity: <85%RH
Working Temperature: 0~55 Degree
Max On/OFF Cycles: > 50,000
Dimensions: 26.0" (L) x 5.6" (W) x 3.6" (H) / 660mm x 141mm x 91mm
BrandADJ
ModelAIR314
Part Number244-4608
UPC818651028119
Weight13
