  • AC Infinity AIRCOM S7 12" Dual Fan Top Exhaust with Thermal Trigger
AC Infinity
Part #305-412
AC Infinity
Part #305-412
Model: AIRCOM S7
This system offers three programming settings which includes two temperature trigger modes. This ensures optimal airflow and noise levels for your application. The fans contain a PWM-controlled motor used to minimize noise during speed variations and are suspended in mid-air with silicone mounts to absorb vibrations. The low-profile design allows this unit to fit in applications with a limited height clearance.
  • This device protects components from overheating, performance issues, and shortened lifespans with a reduction in heat
  • Programming features two thermal trigger modes and four speed control options
  • Contains two dual-ball bearing fans with PWM-controlled motors to minimize noise
Your Price: $49.99
Order in the next 4 hr 6 min to ship today. Details
This quiet cooling fan system is designed to be placed on top of A/V components such as receivers, amplifiers, source units, game consoles, and other A/V equipment. Maintaining an optimal temperature for components prevents overheating, ensures constant performance, and extends the equipment's lifespan.
The controller on the front of the cooling system features a smart thermostat trigger and fan speed control. The steel enclosure houses two dual-ball bearing fans that pulls heat out of the component and exhausts upwards. Its low-profile design enables the unit to fit in tight spaces. The system includes the cooling unit, and a corded power supply in which to power it.
Specifications: • Input voltage: 12 VDC • Wall adapter input: 100 - 240 VAC • Total airflow: 140 CFM • Total noise: 19 dBA • Cord length: 6 ft. • Dimensions: 11.6" x 6.3" x 1.5".
BrandAC Infinity
ModelAIRCOM S7
Part Number305-412
UPC854759004631
Weight2.6
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
