  • 6 Ton Hydraulic Crimp Tool with 8 Dies for Terminals 12 to 2/0 AWG
Part #360-649
Part #360-649
This tool is specially designed to crimp thick metal, large gauge, solderless connectors. The hydraulic action works perfect for power breakaway connectors and battery terminals.
  • Crimps connectors for 12 to 2/0 AWG aluminum and copper wire
  • Hydraulic action makes crimping thick metal connectors possible
  • Hex shaped dies pinch the connector around the wire for a secure hold
  • Includes eight hexagon shaped die sets for multiple size crimp connectors
  • Dies are made of hardened steel with chrome finish
  • Heavy duty plastic case organizes and protects the tool and dies
Your Price: $44.98
MSRP: $49.99
Save $5.01 (10%)
Order in the next 4 hr 5 min to ship today. Details
Always get a tight secure hold with this hydraulic action crimp tool. Its multiple dies pinch the crimp connector on six sides instead of smashing the center of the connector like most crimping tools. The hydraulic pumping action assists in the pressure you put on the tool to make it easier to crimp thick metal, large gauge, crimp connectors. The tool works like a hydraulic car jack, that assist you in lifting up a car.
To get started, insert the right size dies that match the crimp connector and wire that are being crimped. Strip and install the wire inside the crimp connector and insert them in between the correct size dies. Tighten the thumb screw and pump the tool just like a hydraulic car jack until the dies come together. Pull on the wire to verify a secure hold and untighten the thumb screw to release the pressure.
Note: Add hydraulic fluid, if needed, by unscrewing handle assembly.
• Tool dimensions: 12-1/2" L x 1-7/8" D x 4-1/4" H with handle depressed and without thumb screw
• Case size: 13-3/4" L x 6-1/4" D x 3-1/4" H
• Max operation pressure: 6 ton
• Max operating stroke: 10 mm
• Die sizes: 4 mm x 2 (12 AWG) 6 mm x 2 (10 AWG) 10 mm x 2 (8 AWG) 16 mm x 2 (6 AWG) 25 mm x 2 (4 AWG) 35 mm x 2 (2 AWG) 50 mm x 2 (0/1 AWG) 70 mm x 2 (0/2 AWG)
Part Number360-649
UPC848864061702
Weight6.55
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
