  • 8 AWG 50A Breakaway DC Power Connector
Part #263-190
Part #263-190
This 8 gauge battery connector is designed for use as a power quick-disconnect in automotive, RV, and marine applications, as well as other high-current DC charging circuits. Compatible with SMH SY series breakaway DC connectors.
  • Impact resistant polycarbonate housing offers high physical strength and superior dielectric properties
  • 8 AWG battery connector kit rated at 50A, 600 VDC
  • Silver-plated solid copper contacts offer low resistance for superior conductivity
  • Self-cleaning contact design resists arcing by keeping conductive surfaces clean and free of corrosion
  • Contacts have flared and heat treated barrels which readily accept fine stranded wire
  • CE certified
  • Note: Kit includes one housing and two tips (contacts)
Your Price: $4.49
MSRP: $5.99
Save $1.50 (25%)
Order in the next 3 hr 56 min to ship today. Details
76In Stock
These high-current breakaway DC battery connectors are perfect for use as a quick disconnect for car audio amplifier power, RV and marine applications, and other high-current DC charging circuits. Requires two kits for operation, sold individually. Dimensions: 1.88" L x 1.44" W x 0.63" H.
  • CE amperage*/voltage rating: 50 amps/600 VDC
  • Operating temperature range: -20° to 105° C
  • Current rating*: 50 amps on 6 AWG wire produces 30° C rise
  • Insulation with standing test voltage (volts, dc): 2200dc
  • Maximum wire insulation diameter: 0.44"/11 mm
  • Average contact retention force: Approximately 50 lbs.
  • Average contact resistance: With 1-1/4" (32 mm) of 6 AWG wire 200 µΩ
  • Vibration resistance: Excellent
  • Mating cycles: 10,000 / For disconnect use only
  • Impact resistance: High
  • Environmental restrictions: Protected-no hydrocarbon fluids
  • Average mating and unmating force: 15 lbs. (6.75 kg)
* For largest wire or cable size
Part Number263-190
UPC848864031446
Weight0.06
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
