56 Piece Computer & Electronics Repair Tool KitThis 56 piece tool kit has the tools you need to do small computer and home electronic repairs at home. From the soldering iron to the IC extractor this kit enables you to do simple repair jobs instead of sending them out to expensive repair shops.
Note: Remove internal battery saver tab from flashlight before using it.
Tools Included:
• Reversible Ratchet Handle
• 5pcs Socket Set: 3/16”, 1/4”, 5/16”, 11/32”, 3/8”
• 5pcs Socket Set: 6, 7, 8, 9, 10 mm
• 14-Bits Include:
4pcs Square: S0, S1, S2, S3
5pcs Star: T8, T10, T15, T20, T25
2pcs Slotted: 4mm, 6mm
2pcs Philips: PH1, PH2
1PC Bit Adaptor for Socket
• Bit Holder
• 9pcs Allen Wrenches
• 6pcs Precision Screwdriver Set
• Soldering Iron
• IC Extractor
• 5" Wire Cutter / Stripper
• 4 1/2" Side Cutter
• 5" Long Nose Pliers
• Solder Reel
• Solder Wick
• Flashlight
• Battery
• Knife
• 3-Claw Parts Retriever
• Reverse Action Tweezers
• Electronic Tape
• Electronic Voltage Tester
• Blow Mold Case
• Case size : 13.5 x 10.5 x 2.5"
