30 in 1 Extendable Precision Ratcheting Multi-Bit Screwdriver 15 Double Sided Bits
- Durable metal shaft extends from 1.63" to 4.3" to reach into tight spaces
- 14 bits store neatly into the handle while the 15 bit is ready to use
- Double ended bits add up to 30 different tips to fit the most common small screw heads
- Smooth, noiseless ratchet action option increases productivity
- Extendable shaft accepts 14 mm bits for expandability
We'll send you an email when 30 in 1 Extendable Precision Ratcheting Multi-Bit Screwdriver 15 Double Sided Bits is back in stock or available for preorder.
