Belden Snap-N-Seal ProSNS BNC RG-6 Compression Connector 25 PackThis connector is an excellent choice for BNC male termination of both RG-6 and quad shield RG-6 cable.
When Belden acquired the manufacturers of both Snap-N-Seal and F-Conn, the company didn't rest on its laurels. Engineers took technology from both lines to create the best compression connectors in the world: Snap-N-Seal ProSNS.
By providing true 360° compression, these connectors are have superior RF shielding, rated at an effective -85 dB. All three connector styles, F-type, RCA, and BNC, feature 75 ohm impedance for low signal loss. The floating pin insertion guide, low insertion force, low compression force, and innovative sealing O-ring all help to create a connector that's easy to use, reliable, and can be installed using nearly any standard compression tool.
Specifications: • Base metal: Brass • Contact plating: Nickel-tin alloy • Sold per: 25 pack • Entry hole 7 mm • Termination style: Compression • Dimensions: 0.56" x 1.69" (uncompressed).
