  • Belden Snap-N-Seal ProSNS RCA RG-59 Hybrid Compression Connector 25 Pack
4 Questions, 4 Answers or
Belden
Part #092-768
Belden
Part #092-768
Model: FSNS59RCAU
When your time, money, and reputation depend on terminating coaxial cable quickly and reliably, count on Belden Snap-N-Seal ProSNS.
  • RCA plug compression connector fits industry standard RG-59 coaxial cable
  • Integrated O-ring locks out moisture
  • Floating-pin insertion guide for easier installation
Your Price: $69.98
Quantity:Qty: 1-4 $69.98/ea
Quantity:Qty: 5+$68.19/ea
Order in the next 3 hr 19 min to ship today. Details
2In Stock
This connector is an excellent choice for RCA plug termination of RG-59 cable.
When Belden acquired the manufacturers of both Snap-N-Seal and F-Conn, the company didn't rest on its laurels. Engineers took technology from both lines to create the best compression connectors in the world: Snap-N-Seal ProSNS.
By providing true 360° compression, these connectors are have superior RF shielding, rated at an effective -85 dB. All three connector styles, F-type, RCA, and BNC, feature 75 ohm impedance for low signal loss. The floating pin insertion guide, low insertion force, low compression force, and innovative sealing O-ring all help to create a connector that's easy to use, reliable, and can be installed using nearly any standard compression tool.
Specifications: • Base metal: Brass • Contact plating: Nickel-tin alloy • Sold per: 25 pack • Entry hole 7 mm • Termination style: Compression • Dimensions: 0.44" x 1.25" (uncompressed).
BrandBelden
ModelFSNS59RCAU
Part Number092-768
UPC845671004670
Unit of MeasurePackages
Weight0.6
GenderMale / Plug
Mounting TypeCable Mount
