  • 2.5mm Panel Mount DC Barrel Power Jack
Part #090-5014
Part #090-5014
Popular dimension power jacks for projects and repair.
  • Common 2.5 x 5.5 mm internal dimensions
  • Built-in N.C. switch that disconnects the extra terminal to prevent charging alkaline and other non-rechargeable batteries
Your Price: $1.84
MSRP: $2.99
Save $1.15 (38%)
Quantity:Qty: 1-9 $1.84/ea
Quantity:Qty: 10+$1.66/ea
Estimated back in stock 5/15/2025
Alert Me When Available
You can use this common DC jack for projects and internal repairs. Can be assembled tip positive or tip negative for DC applications. Works equally well for AC applications. The terminal connected to the center rivet is tip and the closest terminal to it is barrel. This jack has a normally closed switch built-in that disconnects the barrel to prevent charging alkaline and other non-rechargeable batteries in a portable project. That's what the extra terminal is for.
Specifications: • Dimensions with terminals: 0.9" H x 0.43" D • Mounting Diameter: 0.31" • Current capacity: 3 amps.
Part Number090-5014
UPC848864024295
Weight0.009
DC Power Connector TypeJack
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
