  • 12 Terminal Barrier Strip Jumper Bar 12mm Pitch
Part #090-839
Part #090-839
This 12 position insulated terminal block jumper shunt strip fits 12 mm pitch barrier terminal strips. It conveniently connects all 12 poles without having to use extra wires. Break them into smaller jumpers for barrier strips with fewer poles.
  • Fits 12 mm pitch lug type barrier terminal strips
  • Insulated to prevent accidental electrical shock or short circuit
  • Break them into smaller jumpers for terminal strips with fewer poles
  • Quickly connects 12 poles together
  • Black for polarity identification if needed
Your Price: $2.68
MSRP: $6.99
Save $4.31 (62%)
Quantity:Qty: 1-9 $2.68/ea
Quantity:Qty: 10+$2.41/ea
Order in the next 4 hr 57 min to ship today. Details
444In Stock
Why fool with stripping wires and wrapping them around screws? This insulated 12 position terminal jumper bar connects all 12 poles together in seconds making the whole barrier strip one conductor for positive or negative hook-up. Break it in half and now you have two 6 position jumper bars making one barrier strip positive and negative, or use it on a smaller 6 pole terminal barrier strip. The insulation helps prevent accidental electrical shock or short circuits. Its 12 mm pitch only fits 12 mm pitch lug terminal barrier strips.
Specifications: • Terminals: 12 • External fork width: 0.32" (8.07 mm) • Internal fork width: 0.16" (4.1 mm) • Fork thickness without insulator: 0.033" (0.85 mm) • Total bar width with forks: 5.56" (141.16 mm) • Pitch: 12 mm.
Part Number090-839
UPC848864050157
Weight0.03
