  • #10-32 x 3/4" Rack Screws with Built-in Nylon Washers 100 Pcs.
Part #262-1130
Part #262-1130
10-32 x 3/4" rack screws are perfect for installing rack mount gear, shelves, and panels to your rack case or system. Each screw has a plastic washer to avoid marring your gear, and a high point, easy-start tip.
  • Plastic washer prevents scratching equipment
  • Washer is threaded on each screw to save time and to prevent it from falling off
  • High point, easy-start tip for quick threading
  • Screw's large 0.48" diameter and 0.14" thick carbon steel head securely holds large components
  • Economical 100-pack in secure plastic jar
Your Price: $10.98
MSRP: $19.99
Save $9.01 (45%)
Order in the next 14 hr 49 min to ship today. Details
10-32 x 3/4" rack screws are perfect for installing rack mount gear, shelves, and panels to your rack case or system. Each screw has a plastic washer already attached to prevent scratching equipment and to save time matching washers with screws. Each screw also has a high point, easy-start tip to save time and to help prevent cross threading. The screw's large 0.48" diameter and 0.14" thick head securely holds large components.
Part Number262-1130
UPC848864066509
Unit of MeasurePackages
Weight1.07
Color / FinishBlack
Construction MaterialSteel
Screw Length3/4"
Screw TypeRack Screw
Thread#10-32
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
