- Speakers that are heard, not seen
- Directed audio that you can hear but your neighbors can’t
- Waterproof speakers that will last for many years
- Great sounding audio for the soundtrack to your summer
Dayton Audio offers a large array of indoor/outdoor speakers that are perfect for all types of audio installations. With each version providing both 70V and 8 Ohm operation, the speakers can be used in both residential and commercial applications. Delivering the same great quality that is expected from Dayton Audio, the line of indoor/outdoor speakers produce exceptional audio quality at an outstanding value for both music and paging. Each speaker line contains the mounting hardware needed to quickly install saving time and money. Whatever your needs, Dayton Audio has a line of speakers for you.
Planning and Demonstration Videos
Plan for Your Patio
Choosing the Right Gear
Weatherproof Outdoor Amplifier Install
Bury Your Subwoofer
How to: Bury Speaker Wire
Dayton Audio Landscape Pendant Speakers
If you need mounting versatility, the Dayton Audio pendant indoor/outdoor speaker line provides multiple installation configurations including pendant mount, wall mount, and landscape mount. Complete with 70V/100V and 8 Ohm operation, the pendants can be used with commercial and consumer amps. Constructed from weather resistant ABS plastic, the pendant line stands up to any environment.
Uses:
- Gardens, patios, landscaped audio
- Pools, theme parks, attraction venues
- Entertainment venues, bars, restaurants
- Warehouses, shipping centers
Features:
- Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
- Integrated 70V transformer with selectable taps and 8 Ohm bypass
- Suitable for indoor and outdoor installation
- Available in 4", 6‑1/2", and 8" versions in black and white (4" only available in black)
Dayton Audio WP4BT
Key Specs:
- Woofer: 4" Mineral-Filled Polypropylene Cone
- Tweeter: 7/8" Fabric
- Power Handling (RMS): 20 Watts @ 8 Ohms
- Power Handling (MAX): 40 Watts @ 8 Ohms
- Frequency Response: 80-20,000 Hz
Dayton Audio WP65WT
Key Specs:
- Woofer: 6-1/2" Mineral-Filled Polypropylene Cone
- Tweeter: 1" Fabric
- Power Handling (RMS): 40 Watts @ 8 Ohms
- Power Handling (MAX): 80 Watts @ 8 Ohms
- Frequency Response: 60-20,000 Hz
Dayton Audio WP65BT
Key Specs:
Dayton Audio IOX Series 2-Way Indoor/Outdoor Speakers
If you are looking for bass, Dayton Audio also offers a line of indoor/outdoor speakers that employ a passive radiator to add more low-end. Featuring the same great quality of other Dayton Audio speaker lines, the IOX series provides unprecedented audio for residential and commercial installs. An IP66 certified sealed ABS enclosure protects the speakers from environmental damage.
Uses:
- Larger outdoor gathering spaces
- Pools and theme parks
Features:
- Passive radiator produces extended low-end response for deep, tight bass uncharacteristic of outdoor speakers
- 8 Ohm and 70V/100V taps that are compatible with both consumer and commercial amplifiers
- Sealed IP66 ABS enclosure protects the speaker from water damage making the speaker great for outdoor use
- Available in 6-1/2" and 8" versions in black and white
Dayton Audio IO65XTW
Key Specs:
- Woofer: 6-1/2" Polypropylene Cone
- Tweeter: 1" Silk Dome
- Power Handling (RMS): 50 Watts @ 8 Ohms
- Power Handling (MAX): 100 Watts @ 8 Ohms
- Frequency Response: 45-20,000 Hz
Dayton Audio IO65XTB
Key Specs:
Dayton Audio IO8XTW
Key Specs:
- Woofer: 8" Polypropylene Cone
- Power Handling (RMS): 80 Watts @ 8 Ohms
- Power Handling (MAX): 160 Watts @ 8 Ohms
- Frequency Response: 38-20,000 Hz
Dayton Audio IO8XTB
Key Specs:
Dayton Audio IO Series 2-Way Indoor/Outdoor Speakers
The Dayton Audio indoor/outdoor speaker line provides excellent sound quality in a stylish, contemporary design. Featuring a built-in multi-tap 70V/100V transformer with 8 Ohm bypass the IO line is great for both residential and commercial installation applications. A weather resistant ABS IO655 rated enclosure and aluminum grills ensure the speaker holds up to all environments, indoor and out.
Uses:
- Patio, decks, gardens
- Outdoor gathering spaces
- Businesses, stores
- Bars and restaurants
Features:
- Includes built-in, multi-tap 70V/100V transformer with 8 Ohm bypass for commercial distributed speaker applications
- Stylish, contemporary appearance suits indoor environments as well as outdoors
- Weather resistant ABS plastic enclosure and aluminum grills provide years of service
- Available in 5-1/4", 6-1/2", and 8" versions in black and white
Dayton Audio IO525WT
Key Specs:
- Woofer: 5-1/2" Mineral-Filled Polypropylene Cone
- Tweeter: 1" Metalized Mylar Dome
- Power Handling (MAX): 75 Watts @ 8 Ohms
- Frequency Response: 55-20,000 Hz
Dayton Audio IO525BT
Key Specs:
Dayton Audio IO655WT
Key Specs:
- Power Handling (MAX): 85 Watts @ 8 Ohms
Dayton Audio IO655BT
Key Specs:
Dayton Audio IO800WT
Key Specs:
- Woofer: 8" Mineral-Filled Polypropylene Woofer
- Tweeter: 1" Fabric Dome
- Power Handling (RMS): 65 Watts @ 8 Ohms
- Power Handling (MAX): 130 Watts @ 8 Ohms
Dayton Audio IO800BT
Key Specs:
Dayton Audio Indoor/Outdoor Subwoofers
Add additional low-end with Dayton Audio's indoor/outdoor subwoofers. With a burial and above-ground versions, the subs make adding bass extremely easy to any patio, pool, gardens, or landscaped audio. Both versions are compact and discrete to not disrupt your area's aesthetics. Rugged and weather resistant design ensure a long-lasting life. The sub line delivers outstanding bass and value for any outdoor audio system.
Uses:
Dayton Audio IOSUB
Key Specs:
- Woofer: 10" polypropylene cone
- Power Handling (RMS): 150 Watts
- Power Handling (MAX): 300 Watts
- Frequency Response: 40-300 Hz
Dayton Audio DB8
Key Specs:
- Woofer: polypropylene cone with rubber surround
- Power Handling (RMS): 180 watts
- Power Handling (MAX): 400 watts
- Frequency Response: 25-300 Hz
Dayton Audio Outdoor Bundles
Summer is here, the warmth is welcome, and everywhere you go you can hear the calls of the birds. Join them outside with these outdoor speaker bundles brought to you by Dayton Audio! These packages include everything you need for installation; excluding the pollen!
Small Outdoor Rock Speaker Bundle
Bundle Includes:
- 2x Dayton Audio ROC8S 8" Rock Speakers
- 1x Dayton Audio DB8 8" Outdoor Burial Subwoofer
- 1x Dayton Audio DTA-2.1BT2 Class D Stereo Amplifier
- 3x Dayton Audio WPCC1 Outdoor Speaker Cable Connector
- 500 ft. 16 AWG Direct Burial Speaker Wire
4" Pendant Outdoor System
Bundle Includes:
- 1x Pair of Dayton Audio WP4BT 4" Pendant Speakers
- 500 ft. 16AWG Direct Burial Speaker Wire
- 1x Dayton Audio WPCC1 Outdoor Speaker Cable Connector
Landscape Speaker System Bundle with In-Ground Subwoofer and Amplifier
Bundle Includes:
- 1x Pair of Dayton Audio WP65BT 6.5" Pendant Speakers
How to Bury Speaker Wire
It may seem like a hard task, but burying speaker wire is easier than you think!
We are here to show you how easy it can be to bury speaker wire in your outdoor installations. Follow our step by step instructions for your next outdoor speaker project.
