  • Yorkville C120 Coliseum Mini Series 5" 2-Way Weather Resistant Passive Speaker - Black
Yorkville
Part #245-952
Yorkville
Part #245-952
Model: C120
The Yorkville Coliseum C120 is a high-end, water resistant speaker featuring specially treated drivers and a sculpted ABS plastic enclosure. This compact speaker is ideally suited for many applications: commercial installations, home theatre, home stereo, mobile applications, reference monitor, personal stage monitor and can even be used outdoors.
  • Compact 2-way 100 watt 8 ohm speaker
  • Light weight ABS plastic cabinet with metal grill
  • Bass reflex enclosure with a 5" woofer and 1" amiable swivel Mylar tweeter
  • Mounting U-bracket included
Your Price: $119.00
MSRP: $170.00
Save $51.00 (30%)
The C120 is a bass reflex enclosure with a tuned port and a 5" woofer, which provides improved bass performance over conventional 5" woofer enclosures. Removing the press-fit grille gives access to the eyeball tweeter, which can be swiveled to suit various listening positions. The C120 will handle 100 watts of continuous music and is accurate from 75 to 19,000 Hz.
The C120 is designed to allow a multitude of mounting options including a 'press-fit' microphone stand mount, integral key hole screw-slots or the provided metal U-bracket which allows it to be angled up, down or sideways depending on the mounting orientation. For maximum convenience in live or mobile applications, the back plate features push terminals and dual 1/4" inputs.
Specifications: • Speaker type: 2-way Passive • Power handling: 100 W • Impedance: 8 ohms • Sensitivity: 94 dB @ 1W/1m • Max SPL: 104 dB • Frequency response: 75 - 19,000 Hz • Woofer size: 5" • Tweeter: Aimable Mylar • Inputs: 2 x 1/4", 1 x screw (push) terminals • Cabinet construction: Injection Molded ABS Plastic • Hardware: Mic stand mount, rear key hole mounts (2) / U-bracket • Color: Black • Dimensions: 6.5" D x 6.75" W x 10.25" H • Weight: 3.8 lbs.
BrandYorkville
ModelC120
Part Number245-952
UPC840402011064
Weight7.9
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
