  • Xantech 283D5P Designer Visible/Blinking IR Emitter 5-Pk
CLEARANCE Xantech 283D5P Designer Visible/Blinking IR Emitter 5-Pk
2 Questions, 5 Answers or
Xantech
Part #182-676
Xantech
Part #182-676
Model: 283D5P
The 283D5P Blink-IR Designer Emitter contains a small infrared LED housed in a miniature, diamond shaped plastic shell. Five pieces per package for use on larger jobs.
  • Visible, low-output version of the 282M
  • Deep purple Lexan® shell
  • Clear adhesive film
  • Lead is terminated with a 3.5 mm mono mini plug
  • Length of wire: 10 ft.
The283D5P Blink-IR Designer Emitter contains a small infrared LED housed in a miniature, diamond shaped plastic shell. Unlike other emitters, the 283M emits visible red light in addition to IR (infrared) control signals when activated by IR receivers or other Xantech controllers. The Designer Emitter is designed to be installed directly on the IR control window of the equipment. The almost black (deep purple) shell passes infrared (IR) leaving access to the original remote controller while at the same time making the most unobtrusive installation possible. The designer emitters are made of a deep purple Lexan® for improved infrared pass-through, allowing a greater range of direct control of components from hand-held controllers. Five pieces per package for use on larger jobs.
BrandXantech
Model283D5P
Part Number182-676
UPC042777315536
Weight0.52
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
