  • Xantech 282D Designer IR Emitter
CLEARANCE Xantech 282D Designer IR Emitter
Xantech
Part #182-490
Xantech
Part #182-490
Model: 282D
The 282M Designer Emitter contains a tiny infrared LED housed in a miniature, diamond shaped plastic shell. It emits IR control signals sent to it by IR receivers or other Xantech controllers. The 282M can be installed directly on the IR sensor window of the controlled device or other location.
CLEARANCE $28.00
Order in the next 4 hr 15 min to ship today. Details
8In Stock
The 282M Designer Emitter contains a tiny infrared LED housed in a miniature, diamond shaped plastic shell. It emits IR (infrared) control signals sent to it by IR receivers or other Xantech controllers. The 282M can be installed directly on the IR sensor window of the controlled device or other suitable location. The Designer Emitter is designed to be installed directly on the IR control window of the equipment. The almost black (deep purple) shell passes infrared (IR) leaving access to the original remote controller while at the same time making the most unobtrusive installation possible. The designer emitters are made of a deep purple Lexan® for improved infrared pass-through, allowing a greater range of direct control of components from hand-held controllers.
Specifications: • Non visible, high output version • New deep purple Lexan® shell • Clear adhesive film • Two 1/2" pieces of double-sided clear adhesive tape • Lead is terminated with a 3.5 mm mono mini plug • Length of wire: 10 feet.
BrandXantech
Model282D
Part Number182-490
UPC042777315574
Weight0.5
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
