  • xDuoo MT-604 Desktop Tube Headphone Amplifier
NEW xDuoo MT-604 Desktop Tube Headphone Amplifier
xDuoo
Part #220-308
xDuoo
Part #220-308
Model: MT-604
The xDuoo MT604 Balanced Headphone Tube Amplifier is a compact yet powerful amplifier designed to deliver a warm, detailed sound with the rich character of tube amplification. With its balanced outputs, this amplifier ensures precise audio reproduction with minimal distortion. Ideal for wanting to add the distinct warmth of tubes to their listening experience in a portable and stylish form, the MT604 is perfect for bringing out the best in your headphones.
  • Four 6J1 tubes deliver warm, detailed sound for a rich listening experience
  • XLR and 4.4mm outputs offer a balanced signal to reduce distortion, ensuring clearer and more accurate audio
  • Compact design allows easy portability without sacrificing sound quality
  • Dual volume controls enable precise left and right channel adjustment for to reduce sound bias
  • Ventilation design maintains optimal tube performance for lasting durability
NEW $169.00
MSRP: $240.99
Save $71.99 (30%)
The xDuoo MT604 Balanced Headphone Tube Amplifier is a masterpiece of compact tube amplification, delivering the warm, rich sound that any tube enthusiast will love. Featuring four 6J1 tubes, this amplifier brings out the nuances in your music, providing a listening experience that is both detailed and immersive. The balanced output ensures enhanced audio clarity, reducing distortion and noise to offer a pure, uncolored sound that audiophiles yearn for.
Designed with both performance and portability in mind, the MT604 boasts a sleek, durable aluminum alloy chassis that makes it a stylish addition to any setup. Despite its compact size, this amplifier packs a punch, with dual volume controls allowing for independent adjustment of the left and right channels, giving you complete control over your sound. The MT604 is compatible is made to work with balanced headphones, offering 4-pin XLR and 4.4mm balanced outputs. Whether you're at home or on the go, the xDuoo MT604 ensures your music is heard as it was meant to be, with the added warmth and character that only tube amplification can provide.
  • Input: Two 3-pin XLR, 4.4mm
  • Output: 4-pin XLR, 4.4mm
  • Power Supply: DC12V/2A
  • Output Power: 2,000mW (1KHz, 32 Ohm Load)
  • Dynamic Range: 85dBA (32 Ohm)
  • Frequency Response: 10Hz-60KHz (±0.5dB)
  • Suitable Headphone Impedance: 16-600 Ohms
  • Gain: +15db
  • Signal-to-Noise Ratio (SNR): 115dB
  • Total Harmonic Distortion + Noise (THD+N): ≤0.01% (1KHz, 32 Ohm Load)
  • Size: 6.69" x 3.94" x 2.36"
  • Weight: 1.21lbs.
BrandxDuoo
ModelMT-604
Part Number220-308
UPC981858868786
Weight2.2
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
