Wavecor WF223BD02 8-3/4" Balanced Drive Paper/Glass Fiber Cone Mid-Woofer 8 Ohm
- Vented voice coil former for reduced distortion and compression
- Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced 2nd order harmonic distortion
- Built-in aluminum field-stabilizing ring for reduced high-level distortion
- Large motor structure for better control and power handling
- Copper cap on center pole to reduce voice coil inductance and to minimize variations in voice coil inductance as a function of voice coil position
- New vented chassis for lower air flow speed reducing audible distortion
- rogressive suspension with specially designed conex spider for long durability under extreme operating conditions
Only 2 In Stock
We'll send you an email when Wavecor WF223BD02 8-3/4" Balanced Drive Paper/Glass Fiber Cone Mid-Woofer 8 Ohm is back in stock or available for preorder.
